fog light lamp replacement, burned out. |
bd1308 |
Nov 3 2005, 11:10 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
lamps out...how do i take it apart to replace the lamp?
dumb q i know. b |
r_towle |
Nov 3 2005, 11:16 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I think its easier to see if you take it out of the bumper
There are some fastener on the side of the lense cover |
bd1308 |
Nov 3 2005, 11:19 PM
okay...
as long as thier is a bolt somewhere...i'll figure it out. thanks. b |
pfierb |
Nov 4 2005, 06:28 AM
oldest member Group: Members Posts: 606 Joined: 1-May 05 From: The sign of good government in Connecticut is to keep raising taxes Member No.: 4,008 |
I tried it on my 73 2.0 and couldn't get at the bolts any suggestions short of taking the bumper off? |
SGB |
Nov 4 2005, 10:43 AM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
It has been awhile, but IIRC, the lense surround pulls off from the bottom- sorta hinged by the lip at the top....
Spoke |
Nov 4 2005, 02:00 PM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I just replaced a fog lamp. There is a small screw at the bottom of the unit which holds a small clamp piece to secure the foglight rim. Remove the screw and the rim opens from the bottom.
From there, the lamp socket is clipped onto the reflector and with a small screwdriver, the clip can be removed and the lamp will be accessable. That said, it is possible to do it without removing the bumper if you have hands the size of a small child coupled with the dexterity of a surgeon. The foglight rims on my car were slightly rusted onto the foglight fixture and needed pried loose with a screwdriver. I did this with the bumper off. My bumper was only held on with 2 bolts, one on each side. And of those 2, one snapped off when I tried to remove it. I drilled out and re-tapped all 4 bolts and replaced with shiny new ones from the local hardware store. Now removing the bumper is very easy. If I have to replace another foglamp, I say "off with the bumper". Spoke |
CptTripps |
Nov 4 2005, 02:10 PM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
I second that.... |
fiid |
Nov 4 2005, 07:39 PM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
(IMG:http://www.914world.com/bbs2/html/emoticons/hijacked.gif)
Uh - does anyone know if the stock wiring can handle the "Pilot" replacement lamps? THanks, Fiid. |
pfierb |
Nov 5 2005, 07:38 AM
I guess it's off with the bumper not a surgeon and hands are to big.....Knew I should have gone to med. school. Thanks Paul F. |
bd1308 |
Nov 5 2005, 11:26 AM
Lo-Fi Version | Time is now: 8th June 2024 - 02:34 PM |
