echocanyons |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,109 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California ![]() ![]() ![]() |
Sorry thats nikasil
porsche flat six BTW I would like to clean my pistons and cylinders but I am concerned about damaging the coatings Could I use an engine brite to clean them? How about brake or carb cleaner |
goose2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 976 Joined: 30-March 05 From: Eugene, Oregon Member No.: 3,847 Region Association: Pacific Northwest ![]() |
I've been following a long thread on this on the Pelican 911 board (I'm rebuilding a 3.0)......Popular opinion is that hot soapy water and scotchbrite pads are best for the Nickasils. Don't know about pistons, but I've used Brakleen spray on them....with a soft brass brush on the crowns to get the carbon off. There's probably a better way short of bead blasting (don't blast unless you mask off everything but the top).
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
I doubt if most over the counter cleaners would hurt Nikasil. Doubt if I'd try easy-off though. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) I would stay away from and heavy acid or base cleaners just because of the Aluminum I've bead blasted a 911 nikasil pressure plate...didn't even touch the nikisil. Soap and water won't touch heavy grease...you use that for the final cleaning. |
Lo-Fi Version | Time is now: 31st July 2025 - 11:36 PM |
