| YksKrad |
Nov 12 2005, 10:32 AM
Member ![]() ![]() Group: Members Posts: 72 Joined: 14-February 05 From: Rolla, MO Member No.: 3,602 Region Association: Upper MidWest |
Okay, first things first, I'm on a budget that is basically non existent, so I need to know where toget the best rebuild kit for my buck.
Stock rebuild on a 76' carbed 2.0... I'm basically look for valves, springs, rings, seals, and bearings as cheap as possible... Also are there any types of sealants that wouldn't be found in a rebuild shop that I might need? |
| gregrobbins |
Nov 12 2005, 10:56 AM
Member: Team NARP ![]() ![]() ![]() Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region |
If your budget is really that tight, try to find a running motor and use it until you have the bucks to do it right. Otherwise look in the classisfied sections here, on The Samba, and Pelican Parts. |
| Verruckt |
Nov 12 2005, 12:02 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 716 Joined: 14-July 04 From: Midwest Member No.: 2,348 |
The one thing I have found with these cars, is that "tight budget" and "best" are 110% incompatible.
It's one or the other. |
| Bleyseng |
Nov 12 2005, 12:45 PM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Cheap valves? you can use Stainless steel valves BUT the seats and guides need to be replaced by a PRO. The valve seats tend to fall out if not done properly and witha few tricks.
A cheapo rebuild shop can and will crack and or ruin a set of 2.0l heads as they are fragile when installing new guides. Most 2.0l heads suffer from cracks from the spark plug hole to the valve seats and it needs to be drilled out and welded up. Len at HAM or Adrian at Headflowmasters are the shops I would recommend for headwork. bearings and rings and all can be had from Jake's store, PP, GPR etc. |
Lo-Fi Version | Time is now: 3rd March 2026 - 04:13 PM |
