| Britain Smith |
Nov 15 2005, 11:02 PM
Nano Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
I know this guy...he is looking to purchase a 914...wants to be really fast on the AX course...and can't decide between an original 6 (or conversion) w/ 2.7L (or some sort of uprated motor) or a Raby (or similar) four cylinder.
Putting the discussion on equal playing grounds, lets say that both chassis are identical, which would be faster on the AX course? This is assuming a well built chassis, with a cage, upgraded suspension, hoosiers (or similar) tires, etc. For AX purposes, my vote would go for the 4-cylinder car all the way. I have my reasons, but I want to hear yours first...so which is it? -Britain |
| Andyrew |
Nov 15 2005, 11:06 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
Well, a T4 can make a bunch of tq (autox good) and also built properly, rev high.
Then there the fact that the T4 is also lighter... Equally built, ie, same car, throw in a 150hp 4 in, take times. throw a 160hp 6 (added power due to added weight), and 40lb stiffer springs.. the 4 I believe would be faster... But you cant make 300hp very easily from a 4... |
| SirAndy |
Nov 15 2005, 11:08 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
in my experience, the powerband of a warmed over /4 is better suited for AX ... the /6 takes too long to spool up and needs to be run at too high RPM which is a disadvantage for courses with a lot of tight corners and not many long straights. of course, that's just MHO ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
| McMark |
Nov 15 2005, 11:13 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Sixes, and especially bigger sixes, take much more finesse to drive. I'd vote for a hot four. Maybe a high revving (7500) 2056.
| Mueller |
Nov 15 2005, 11:14 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
at least in our region we have "proof" (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
a /4 took top honors for every event they came out to...only time a /6 won was when the /4 car didn't show up (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
| Jake Raby |
Nov 15 2005, 11:16 PM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Oh no- This is gonna be a heated one....
I'm going back to the machine shop now ...... |
| J P Stein |
Nov 15 2005, 11:25 PM
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
By all means, get a T-4.
| john rogers |
Nov 15 2005, 11:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
I think it depends on the driver! If you look at the Porsche Parade as an example, 914-6s have been TTOD for years with few exceptons (hot rod 911s for instance). At local venues, where space is restricted somewhat, a lighter 4 cylinder car with a well built short geared trans, sticky tires, etc will be about unbeatable. Until James Gunn-Wilkenson comes along with a Turbo 930 of all things and even beats tube framed 914s!!! Now he at least moved to a GT2 and is winning SCCA Pro-Solo, but anyways, like I said it is the driver.
| DanT |
Nov 15 2005, 11:34 PM
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
Part of the reason that Andrew B has done so well with his car is it has been lightened....way light.
No one I know with a 914-6 has gone to the extremes that Andrew has. Andrew is a very good Axer and drives the car to its max. A well built 2.7L with similar weight would be hard to beat with equal drivers. I chose a 2.7L RS spec since they have a very good torque curve especially at the mid RPM ranges that would be used coming off corner in an AX. Bill Pickering used to get pretty close to Andrew with a car that had much more weight and his car was really set up for TT not for AX. Andrews car is a very well set up AX car not a multipurpose car that most folks have here in Norcal. Just my $9.14 worth. |
| brant |
Nov 15 2005, 11:36 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,167 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
How light is his car?
is this the dark car with the white arrow? brant |
| drgchapman |
Nov 15 2005, 11:39 PM
Current Stable ![]() ![]() ![]() Group: NoClassifiedAccess Posts: 922 Joined: 20-September 04 From: Portland, OR Member No.: 2,789 Region Association: Pacific Northwest |
I'm just gonna lurk for a while.......... (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif)
| DanT |
Nov 15 2005, 11:44 PM
No his car is kinda of "Grabber Blue" with parts of a Chalon kit.
Just about anywhere you look there is fiberglass or no metal, like trunk floors, no motor tin, no glass anywhere I am not sure of the weight but it must be below 1500# ( only a guess) |
| gregrobbins |
Nov 15 2005, 11:52 PM
Member: Team NARP ![]() ![]() ![]() Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region |
In the Arizona Region, PCA, we get to watch this play out at the autocrosses. Andy has his Wild6 with a 3.6L, Brian Willis had a 3.0L, Jack Amen has a 2.7L, Paul has a healthy four and Tim has a fire snorthing 2.0L four with a hot cam and a body that weighs in at about 1800 lbs.
The sixes are posting better times season to date. None of them are too happy though, a Boxster S with Hoosiers has taken ttod two out of three events. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Me, Student Driver, I just sit back in CP with my stock 2.0L and watch them slug it out. (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) |
| EMRoadster |
Nov 15 2005, 11:59 PM
Autocrosser ![]() ![]() Group: Members Posts: 65 Joined: 20-August 05 From: Tucson, AZ Member No.: 4,620 |
Greg R. How many of these guy's do you expect at the AZ Region PCA event this Sunday? I'm planning to try to attend myself and would love to see this in action. |
| Trekkor |
Nov 16 2005, 12:00 AM
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
How shall I say...Wrong!!! KT |
| nebreitling |
Nov 16 2005, 12:01 AM
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
if i were building an AX-only car it'd be a /4 for the weight break. look at trekkor's car vs mine (similar level of preparation): he has undoubtedly more power than i do (that six just flat hauls ass), but he doesn't get on the cam until 6k. i got torque.
that said, there's always the Fordahl 914-6.... |
| gregrobbins |
Nov 16 2005, 12:04 AM
I bet you will see Andy, Brian, Tim and Jack for sure. Paul should be there as he likes the layout. Dave probably will drive up from Tucson. I will be in California and will have to miss this one. |
| airsix |
Nov 16 2005, 12:08 AM
I have bees in my epiglotis ![]() ![]() ![]() ![]() Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
JP, Is that endorsement free of any conflicts of interest? (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) I watched a 914-6 w/ 260hp (saw the dyno sheet) 2.7 dominate our club for 10 years. No -4 ever came close and many tried. No contest. Same can't be said for a 914-6 2.0, 2.2, 2.4. Those got beat by -4s periodically. But a big 6? All else being the same the six will clean up. -Ben M. |
| gregrobbins |
Nov 16 2005, 12:09 AM
In Phoenix we have one guy with a Raby 2270, but I can not get him to come out to autocross. I would love to see how that car would do in the hands of an experienced driver compared to the sixes.
As to which is better, driver and suspension have a lot to do with the final outcome. A 2270 built right would have the six guys scratching their heads. Maybe not beat them, but sure give them a run for their money. |
| Trekkor |
Nov 16 2005, 12:39 AM
Exposure #1
Provasi drives a SIX. My car was the fastest street legal 914 (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) http://lpr.pca.org/ax/2005/lprax6/lprax6.htm KT |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:20 AM |
