Cam rivits, remove ing gear or buy one? |
qa1142 |
Nov 20 2005, 12:43 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
So, old cam is rivited
Do I remove them? (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) How???? Or just buy a new / good used Gear? |
Mark Henry |
Nov 20 2005, 12:46 PM
Are you trying to save the gear or put a new gear on the cam????
Not a thing to cheap out on. So what's the skinny? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
qa1142 |
Nov 20 2005, 12:49 PM
asking
didn't "plan" on new cam gears..... Not cheap just didn't think I needed them |
Mark Henry |
Nov 20 2005, 12:56 PM
So....you need a cam gear is it?
New, if you want to use the old one machining is involved. |
Demick |
Nov 20 2005, 12:57 PM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
Better to buy a new one. They are only about $30 or so. If you try and re-use the old one, you will have to drill out the rivets, and then have the holes in the cam gear counterbored to make room for the bolt heads. If you don't counterbore, then the bolt heads will hit the oil pump. Just not worth it for $30.
Demick |
qa1142 |
Nov 20 2005, 12:59 PM
Jake Raby |
Nov 20 2005, 04:48 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Most of the stock cams are magnesium and WILL fail given the opportunity.
I'd replace it. |
Joe Ricard |
Nov 20 2005, 07:57 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
No wonder we have lifter and cam failure. The frigging cams are magnesium. (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) Yea Yea I know what you ment but I still can't help it. (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) |
qa1142 |
Nov 21 2005, 12:13 PM
Ok
So new gear, got it (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) I bought Jakes 5022 "oil pump RAT Mod 26mm #5022" Is that a type one that needs the type one mod gear or type IV? |
Jake Raby |
Nov 21 2005, 08:17 PM
you need a RAT 8312- Thats the gear that matches your pump..
My above post shoudl ahve read "Cam gear"- not "CAM" BTW- we are going over the store site everyday, soon all the pumps and cam gears will be sold as matched sets only, I'm tired of all the questions associated with the compatibility- |
qa1142 |
Nov 21 2005, 08:36 PM
How about editing web site to say which gear goes with each pump? (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif)
Anyway, sent you an order for the gear (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
Jake Raby |
Nov 21 2005, 10:21 PM
Its more difficult than that.... Then everyone wants to use their stock gear the way you did!
This way their is no confusion- they are a matched pair.. Same thing goes with cams and lifters, oneis not available without the other.. |
Lo-Fi Version | Time is now: 8th June 2024 - 01:55 PM |
