dlo914 |
Whatchu' lookin' at?!?! ![]() ![]() ![]() ![]() Group: Members Posts: 3,433 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 ![]() |
well i got one the other day at the FLAPS.i got one because i dont usually have a 2nd set of hands to help me crank over the engine to check for spark n stuff. But where do i connect it to? one to the positive terminal on the battery and the other clamp to? Thanks in advance (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
to the terminal on the starter that has the yellow wire going to it.
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
one goes on the big terminal on the starter /positive battery lead...the second goes on the smaller terminal on the starter.
Rich |
dlo914 |
any pictures?
Brando |
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California ![]() |
Get one of those big push-button starters at a FLAPS or a little button.
Run a wire from the + terminal of the battery on one side of the switch. Run a wire from the small spade-connection on top of the starter (you'll feel it on top between the two big bolts on back) on the other side of the switch. When you need to crank it over, just hit the button. If you'd like I can hook up my old "theft deterrent" on your car to show you. |
auggie91420 |
Newbie ![]() Group: Members Posts: 41 Joined: 6-July 05 From: Altadena, CA Member No.: 4,380 ![]() |
One lead goes to the stud on the solenoid that has the 13mm nut. Just to the right are several male posts, one of which has the yellow wire attached. Put the other lead on the spare male post, fire away (in neutral!).
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
There are TWO posts with a 13mm nut on the solenoid. The one with the battery cable is the one you want to use. The Cap'n |
Brando |
BTW: Jumping one 13mm nut to the other will spin the starter, not engage the solenoid. (IMG:http://www.914world.com/bbs2/html/emoticons/poke.gif) |
Lo-Fi Version | Time is now: 4th July 2025 - 11:48 PM |
