Installing Sway Bar, Anything else "while I'm at it"?? |
vesnyder |
Nov 23 2005, 06:22 AM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
I removed the fuel tank last night to replace it and purchased a sway bar to install while I have it removed. Also going to install a 19mm master brake cylinder while I have access to the brake fluid feed lines and some general clean-up and POR-15 some surface rust spots - anything else I should do while I am in there and have the fuel tank removed?? Messing around with teh fuel and draining the tank is not something I want to do twice?
Thanks |
Trekkor |
Nov 23 2005, 07:36 AM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
If you were thinking of replacing the fuel lines up the tunnel now would be the time.
KT |
Allan |
Nov 23 2005, 08:01 AM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) And fuel filter if you have one up front. |
J P Stein |
Nov 23 2005, 11:26 AM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Are you feeling feverish? It's begining to sound like a case of DWD (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
sean_v8_914 |
Nov 23 2005, 11:39 AM
Chingon 601 Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
relocate teh fuel pump to the front
check your defrost/ventilation blower windshield hasher system |
sean_v8_914 |
Nov 23 2005, 11:40 AM
I just did all this stuff, here's how
http://www.914world.com/specs/tech_fuelline...f7071cbbf310d4d I ran a guide wire through my lines, then removed teh plastic while keeping the guide wire in place |
sean_v8_914 |
Nov 23 2005, 11:41 AM
PS. thanks Clay
Lo-Fi Version | Time is now: 10th June 2024 - 04:22 PM |
