fuel pump, pressure check |
toon1 |
Nov 23 2005, 11:51 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
Is there a way to make a setup to check the fuel pressure on the pump before installing it in the car?
r_towle |
Nov 23 2005, 11:59 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
put a line with a fuel pressure guage in the middle...
Run it from the d port to a fuel pressure regulator and back to your gas can. Run another line from your gas can to the s port on the pump. The power is 12V pos and ground... Rich |
toon1 |
Nov 24 2005, 09:45 AM
the pressure gauge goes between the pump and the press. regulator?
SLITS |
Nov 24 2005, 10:21 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Yes |
Cap'n Krusty |
How else will it read the pressure? The Cap'n |
toon1 |
Nov 24 2005, 12:27 PM
Just wanted to make sure, thank's guy's.
toon1 |
Nov 26 2005, 06:20 PM
I made the setup and checked the pump, got good pressure but I was getting fuel drizzling out of the R port. Is that normal?
srb7f |
Nov 26 2005, 10:45 PM
Member Group: Members Posts: 157 Joined: 17-May 04 From: Roswell, GA Member No.: 2,077 Region Association: None |
Speaking from past experience here, be very careful when attaching electrical wires to a fuel pump testing contraption with fuel drizzling out...all it takes is one spark to create a garage fire for you. I was lucky and had a fire extinguisher in the trunk, but instead of messing with this, I'd suggest just hooking up the hoses and attaching the fuel pressure gauge to the fuel ring. Steve
Lo-Fi Version | Time is now: 8th June 2024 - 06:53 AM |
