Fuel leak!, ...the smell of gas in a closed garage! |
DblDog |
Dec 5 2005, 10:45 PM
Member Group: Members Posts: 164 Joined: 8-February 05 From: San Rafael, CA Member No.: 3,578 Region Association: Northern California |
...so I take my car out...get it filled up and take a ride. Top off , cool crisp fall Sunday morning...great fall colors..the second best way to start a day! Park in the garage, lets put up some Christmas decorations. All in all a good day.
Walk by the teener through the garage...and there it is...the smell of gas... (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) open the garage door let it air out. Get home early, lets take a look at that leak. Its coming from the fuel filter, no problem...but then in moving the filter around, one of the clamps lets go...and remember I got a full tank of gas yesterday...the flood gates open. 2 or 3 golf tees and get the leak to slow to a drop or two. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) Here's the question...I need a shop to fix this little problem as I can't take time away from my work right now. Do any of you know of a repair shop nearby that can take a look at this?...I'm in the north bay (Marin County)...Ill'have to have AAA tow it to whever...I welcome any recommendations...Thanks! |
jimtab |
Dec 5 2005, 11:44 PM
Advanced Member Group: Members Posts: 3,477 Joined: 5-January 03 From: Pacifica, California Member No.: 91 Region Association: Northern California |
See if Mark can take care of it, he is in Napa...the only one that I know in that area....hope it helps. Gas leaks are scary....his club name is mcmark
bperry |
Dec 6 2005, 11:13 PM
Lurker Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 |
I'd think it would be at least worth considering just replacing the filter
to see if that stops the leak. Given that the clamp came loose as you moved the filter, it could be as simple as a clamp that was too lose or too tight and it cracked the plastic filter. Also, I had a filter crack/split because during driving it was vibrating and bumping against the frame and over time it simply cracked. To try this fix will only cost a few dollars and take only a few minutes; definitely less time than the time lost waiting for AAA or anybody else just to show up. If its not the problem, you are only out a few bucks and a few minutes of time. --- bill |
McMark |
Dec 7 2005, 12:44 AM
I'm probably a little far away and I've got no floor space for another car. But I might be convinced to make a house call. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) A quick filter and hose replacement. Should be good as new. I'd have to charge you for travel time, but I'll probably still be cheaper than any other local shop. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Lo-Fi Version | Time is now: 9th June 2024 - 08:41 AM |
