Need a way to glue a sparkplug in. |
Bleyseng |
Dec 13 2005, 06:44 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
The Westy puked a plug and I tried JB Weld to hold it in but that didn't work....Just need to drive it back to the shop across the lake of course (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
PO had stripped the plug and I knew it wasnt the best, got new heads and all ready to go in. Any ideas???? (IMG:http://www.914world.com/bbs2/html/emoticons/WTF.gif) |
john rogers |
Dec 13 2005, 06:50 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
Try a spark plug insert, they look similar to a helicoil or other thread insert.
bondo |
Dec 13 2005, 06:52 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Leave that plug out, ground the plug wire, and disconnect the power to that cylinder's injector.. then just run it on three! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Aaron Cox |
Dec 13 2005, 06:56 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
a wsty is gutles on 4.. 3 would be way painful! |
bondo |
Dec 13 2005, 06:58 PM
Well it doesn't matter much, as they don't float.. It'll sink before he even gets halfway across the lake. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
r_towle |
Dec 13 2005, 07:16 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I would agree... Or , cross thread a lug bolt in there for the ride. Rich |
Bleyseng |
Dec 13 2005, 07:21 PM
No way will it make it up the hills around here!!! This isn't the Mid West its Seattle-Bellevue and the damn thing is stuck out in Issaquah at the HomeDepot.
r_towle |
Dec 13 2005, 07:32 PM
either a plug insert,or, you could make a bracket that has three holes in it...
The middle hole goes over the plug. The other two holes could be used to screw right into the now scrap head to hold the plug down... I did this with an oil plug on a generator...it works... I would say that, or even PVC to hold it down...it only has to last 20 min...and it has only 100 psi.... Go back into home depot with a plug...find a pipe that will fit over it, some rope, some duct tape...a coat hanger,,,and some jb weld... Just strap it in. BTW, It will make it with three, it just will be slow...but it will make it. Rich |
Bleyseng |
Dec 13 2005, 08:47 PM
Yeah, I might drive it all the way around the lake or have it towed.
IronHillRestorations |
Dec 13 2005, 09:14 PM
I. I. R. C. Group: Members Posts: 6,732 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I'd go with the plug insert. You've got to tap the spark plug hole. You put grease on the cutters to catch the metal shavings. Then you thread the insert and smack it with the tool to lock it in place. Works pretty good and should hold for a long time. Stay away from Champion spark plugs, and always put a wee bit of anti seize on the spark plug threads. Jake says milk of magnesia works good for this too.
914werke |
Dec 13 2005, 09:45 PM
"I got blisters on me fingers" Group: Members Posts: 10,150 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Have Blair push (IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif)
dmenche914 |
Dec 13 2005, 10:09 PM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
Run on three. My Dad drove the family home from Oregon many many years ago, on three when a cylinder died in his 50 hp Microbus. Part way back the second cylinder died, limped home on two. I recently drove my bug home with one plug pooped out, noisey, but it works.
Jake Raby |
Dec 13 2005, 10:29 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Sounds like you have a cracked head... Cracked heads can't hold a spark plug in them when the engine heats up and the head expands...
If JB Weld won't hold it pretty much nothing will... don't use JB KWIK- its not real and not worth a damn. Old school JB weld in the red and black package is the real stuff and it will hold most anything if it cures for 24 hours... Running on 3 cylinders taxes the entire engine and will generally cause more issues and wear more parts. |
Bleyseng |
Dec 13 2005, 10:32 PM
shit, I used the JB Kwik so I'll try the real stuff
Jake Raby |
Dec 13 2005, 11:21 PM
Thats why it didn't hold...
JB Kwik is a sorry product.... The real shit rocks! |
Joe Ricard |
Dec 14 2005, 06:27 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Hmm guess I can go home now... I lernt sumpin else today and it's not even 6:30
JB weld does rock. didn't know about the quick stuff. Used to be some stuff called FASWELD comes in a 2 part putty. won't work for this situation. |
DNHunt |
Dec 14 2005, 08:29 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Tow it.
Your time is worth more than the tow bill. Dave |
Dr. Roger |
Dec 14 2005, 12:10 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
JB probably didn't hold due to no threads to grab on to. IMHO.
the real stuff will take the heat for a little while.. but exhaust temps??? yikes. if you really dont care about the head, just go down to your local parts house and get a spark plug that has threads one size larger and cross thread that puppy in. create your own new threads... (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) american or foreign.. theyll all work. just needs to be a larger diameter. |
Lo-Fi Version | Time is now: 14th June 2024 - 08:58 AM |
