A solid day of welding, and the last flare................... |
East coaster |
Jan 7 2006, 10:34 PM
Senior Member Group: Members Posts: 1,687 Joined: 28-March 03 From: Brigantine, NJ Member No.: 487 Region Association: None |
Buried myself in the garage today and managed to get my last GT flare attached and even got to a few rust spots.........the project progresses (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif)
Here's the passenger front (and the last) flare being tacked on: Attached image(s) |
East coaster |
Jan 7 2006, 10:36 PM
nuther.....
Attached image(s) |
East coaster |
Jan 7 2006, 10:37 PM
clamps removed and more welding.....
Attached image(s) |
East coaster |
Jan 7 2006, 10:38 PM
nuther....
Attached image(s) |
lincoln |
Jan 7 2006, 10:40 PM
Member Group: Members Posts: 174 Joined: 9-December 05 From: Killeen Texas Member No.: 5,253 Region Association: None |
looks good
and to think i almost bought that same welding hood lol |
East coaster |
Jan 7 2006, 10:41 PM
Took a flat body file to the top of the flare to highlight the ripples (shiney spots) that you get with AA flares. It helps mark them and then it's hammer and dolly time to work them out. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
Attached image(s) |
East coaster |
Jan 7 2006, 10:51 PM
Took care of a couple of rust spots also. Here's a nice hole in the bottom of the drivers rear quarter panel.
before......... Attached image(s) |
East coaster |
Jan 7 2006, 10:52 PM
and underneath...........
Attached image(s) |
East coaster |
Jan 7 2006, 10:54 PM
after........
Attached image(s) |
East coaster |
Jan 7 2006, 10:56 PM
and under....
Attached image(s) |
East coaster |
Jan 7 2006, 10:58 PM
Made a commitment to Sirius radio too...........welded up the am/fm antenna hole!
Attached image(s) |
East coaster |
Jan 7 2006, 11:01 PM
Repaired a wierd rust spot at the front bumper mount (dog bone). This was a pain in the ass, it's three layers thick here and all three were affected. The support bracket behind needed two patches and everything in front of the bracket had to be replaced (2 layers).
here's a front shot...... Attached image(s) |
East coaster |
Jan 7 2006, 11:04 PM
from behind.....
Attached image(s) |
East coaster |
Jan 7 2006, 11:07 PM
That's it for today. The flare is about ready for filler and the rust spots just need to be dressed. The drivers side jack post area is the only rust spot left unadressed and it should be taken care of tomarrow.
Luke M |
Jan 8 2006, 01:35 AM
Senior Member Group: Members Posts: 1,373 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Nice job (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) I'll be installing my flares next week.
Any problems that you ran into? Luke |
East coaster |
Jan 8 2006, 06:50 AM
Best advice I can give is make sure you clean all welding surfaces very well, both inside and out. Any burning paint/undercoating/seam sealer will deplete the welding gas and give you a nice hole in the bead. On the first flare I neglected to prep the inside of the fender well enough and got some burn through. Also, be patient and weld small areas at a time (1" or so) to minimize heat warpage. The little extra time you take here will be saved 10 fold on hammer and dolly time.
If you're doing AA flares, you'll have to work the bottom of the flare into the stock bottom line. The AA flares are flat on the bottom and the stock were angled at the rocker line. A little hammer/dolly work will blend it from angled to flat. Here's a pic for clarity: Attached image(s) |
East coaster |
Jan 8 2006, 06:51 AM
from inside.........
Attached image(s) |
URY914 |
Jan 8 2006, 07:23 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,944 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Very nice work! And I would say not your first time. (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif)
Jeroen |
Jan 8 2006, 08:59 AM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
wish the DPO of my car repaired the bumper mounts like you did the way they are now makes me wanna (IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif) |
IronHillRestorations |
Jan 8 2006, 09:57 AM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
That may be a little better than the factory flares |
Lo-Fi Version | Time is now: 1st June 2024 - 02:09 AM |
