KJJ-74-914 |
Newbie ![]() Group: Members Posts: 30 Joined: 28-November 03 From: Antioch, IL Member No.: 1,401 ![]() |
I have a 1.8 converted with a larger Bore and Euro Pistons. Do I adjust the valves for a 1.8 or 2.0 engine?
I see the spec is the same. Never mind...thanks for looking though!! |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,200 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
The spec is not the same. Valve gaps on the 1.8 motor are 0.006" for both intake and exhaust. The 2.0 motor, with its sodium-filled exhaust valves, uses a 0.008" exhaust valve gap, but the standard 0.006" intake gap.
Unless you found some (very rare) sodium-filled 1.8 exhaust valves, use the 0.006" spec just like a standard 1.8 does. --DD |
Lo-Fi Version | Time is now: 11th July 2025 - 05:45 AM |
