1bad914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 618 Joined: 6-May 04 From: Battle Creek, MI Member No.: 2,028 ![]() |
Anyone have any hands on experience with ther Holley pro-jection system, 2d or 4d? Thinking of putting FI on the 327 and was looking for feedback.
bondo |
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California ![]() |
I have a 2D on my mustang with a 302. I hate it. It's an older one with no load sensing. If it had a MAP sensor it'd probably work much better. Andyrew says his has a MAP sensor, but I don't know what model he has.
1bad914 |
It's between the Holley 2d/4d or a stock TBI setup from a late 80's SBC. The 4D has all the bells and whistles, but is much more costly. Typical 914 CSOB syndrome. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
boxstr |
MEMBER:PACIFIC NORTHWEST REGION ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest ![]() |
I have the 2D on a 305 Chev in a 914 and it works perfect.
CCLINHOLLEYHEAVEN |
1bad914 |
What kind of HP is the 305 producing? I guesstimate my 327 at just below 300.
Dr. Roger |
A bat out of hell. ![]() ![]() ![]() ![]() Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California ![]() |
Andyrew is also running the Holley pro-jection i think ....
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
Im using pro jection... Its almost like a standalone unit.
Im not good enough to tune it though, and Havent put the other things on to have it tuned by a dyno. If it had an "autotune" then it would run like a new car... Its got 2 temp sensors, a map sensor, TPS, O2 sensor, Electronic dizzy programabiliy, Temperature compensation, knock sensor, voltage, oil pressure, you name it... Andrew |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
i'd Megasquirt it (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
tons of Chevy guys on the MSEFI.com forums, tuned port to holley prection type setups..... |
tesserra |
Member ![]() ![]() Group: Members Posts: 210 Joined: 26-March 03 From: Lafayette CA Member No.: 479 ![]() |
I have the Holley 2d. I would not do it again.
I have a lot of "tip in" throttle issues that are hard to tune out. I looked on e-bay before and got a bunch of info on a guy that uses a stock bases tbi system with a distributor control and tweaks it to your specs. It was about $300 more than the 2d, but in the long run it would be cheaper and all his parts could be replace with stock GM units in case of a break down. I do not have the o2 senser on my 2d system and I understand that that could help, but it only tweaks the program very little, and it was about $200. The bottom line is the 2d is, for the most part, RPM and temp sensitive only. Check on four wheeler forums, they use efi conversions because of the wierd position/float bowl situations they get into. You will find a lot of info there. George |
motorhead |
Member ![]() ![]() Group: Members Posts: 67 Joined: 11-September 05 From: tehachapi, ca Member No.: 4,784 ![]() |
A friend of mine is runnng one on his 41 willys rock crawler. Lots of little problems, but he seems to have gotten it tuned pretty well now.
Maltese Falcon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,063 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None ![]() ![]() |
I use the 4D on the 350 LT1 in this VW Transporter. It is ez to tune (by the book).
I do suggest using a fuel pump kill, as the Holley "Clear/ flood" mode on the TPI is finicky and doesn't always allow good hot restarts. A momentary switch as stated eliminates that problem. It was priced about equal to a 750 cfm 4bbl Holley, and fell right on top of the Edelbrock Vic-jr. manifold (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) I'm also using the Bosch fuel inj. pump instead of the Holley unit. The tech advised that the Holleys would cause erratic running in time. Attached thumbnail(s) ![]() |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
I like the 3d better...its looks more realisitc and I feel like I am almost part of the scene.
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) Whoah baby. Cannot resist the hijack... Marty, do you have a link to a web page or more photos or anything on that Transporter? Cool.
r_towle |
snflupigus |
Member ![]() ![]() Group: Members Posts: 320 Joined: 29-May 05 From: Gilbert, AZ Member No.: 4,163 Region Association: None ![]() |
I used to do a lot with gm throttle body injection... (on a third generation camaro)
Here is a quick gist of what you can now do with one of the cheapest most reliable fuel injection you could put on a car. http://thirdgen.org/techbb2/showthread.php...t=&pagenumber=1 When these guys started out on those boards i knew more than they did.... now they've written software and designed circuits to completely redefine and recreate throttle body injection into a cheap feasible diy efi. with readily available parts everywhere. btw, i'm told thirdgen.org is now the largest enthusiast website on the internet... and its 100% tech with no OT |
Maltese Falcon |
Rand, here's another. I need to scan all of my German8ter build pictures and post them . Do you think that the OT Patrol will be offended by this non-914 content ?
Now back to topic Holley Projection Pleeze (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) Attached image(s) ![]() |
r_towle |
possible 914 system there?
Rand |
Martin: I love it! Yes, fire up the scanner... Pleeeeze start an OT thread on that German8ter beast some day soon!!! It's a moral imperative. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Now back to your regularly scheduled programming... |
bondo |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) And if you were wondering where to start.. may I suggest the water pump? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Lo-Fi Version | Time is now: 1st July 2025 - 01:54 PM |
