914-4 CV Joints, Bolt Torque |
tyler |
Jan 27 2006, 01:01 PM
Member Group: Members Posts: 335 Joined: 24-September 03 From: southern california Member No.: 1,192 |
I had a joint come apart with, thankfully, no damage. It looked like the 4 capscrews just loosened up and separated the joint. Before I replace the bent cap screws and put it back together, I thought I'd ask for the following info from the experts:
1. What should they be torqued to? 2. Should they have lockwashers? 3. How about installing a lockwire thru the 4? Thanks |
DNHunt |
Jan 27 2006, 01:10 PM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
I believe they are 31 lb ft. They take a washer called a Schnoor washer. I know they are available at Pelican.
Dave |
r_towle |
Jan 27 2006, 01:12 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
my race car had lock wires on them..I have lost one at 30 mph...it was not fun...
I agree with racing wire through the bolt. There is a thread here or on pelican that shows how... And yes, get new washers, the right kind, and clean and torque to spec. Rich |
hmeeder |
Jan 27 2006, 11:22 PM
Dante's Sportscar Group: Members Posts: 352 Joined: 21-November 04 From: San Diego, CA Member No.: 3,154 |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) |
lincoln |
Jan 27 2006, 11:29 PM
Member Group: Members Posts: 174 Joined: 9-December 05 From: Killeen Texas Member No.: 5,253 Region Association: None |
drivers side? thats the one i had work itself loose, what i did - that so FAR has worked- is i hit them with locktight red and added regular lockwashers - replacement bolts came off a bug trans so were slightly longer anyways- then torqued the hell out of them- just to be on the safe side tho im carrying an allen wrench in my pocket and i check them everytime i get ready to go somewhere- only takes a minute to check- takes hours to fix if they come out again
IF they come loose again , i will be going with an ARP grade 8 or better thru bolt and lockwashers and locknuts and possibly wire |
john rogers |
Jan 27 2006, 11:36 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
Being the paranoid racer that I am, I lock wire mine and also the bolts are slightly longer and have jam nuts on the backside of the flange.
Lo-Fi Version | Time is now: 10th June 2024 - 09:09 AM |
