Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
As promised-
Autopower bolt-in with diagonal brace. KT Attached image(s) ![]() |
Trekkor |
utter side (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
awesome. thanks trek
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,908 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
aaron there is 2 models the one I had bolted to the floor ,Trekkor 's bolts/welds to the top of the long
Trekkor outside daytime full shots of your new paint (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) |
dheinz |
cross member ![]() ![]() Group: Members Posts: 122 Joined: 7-August 03 From: Pittsburgh, PA Member No.: 995 ![]() |
Trekkor,
Is that rollbar legal by any sanctioning body or is a full roll cage needed? I like the looks of the bar but don't want a full roll cage for occasional street use. Where can I get an Autopower roll bar? Thanks, Eddie |
Trekkor |
Honestly, I don't know (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) I have it in there for added safety for the limited number of DE's I participate in. I think SCCA, NASA , etc require the full cage. I'm toying with the idea of welding additional tubing to convert it to a true cage. Like the fire extinguisher? KT |
DanT |
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None ![]() |
My roll bar bolts to the floor and has a removable diagonal brace. I will run with the petty bar in but no diagonal. Makes it too hard to have students ride in the car. Between the petty bar and the seat being so far forward fromt the diagonal, makes the students very claustrophobic. If I do any door to door racing I will bolt in the diagonal, since I won't have any riders. Like club racing.
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Me thinks that other than added wieght the roll bar pictured don't do nothing but sit there and be heavy and get in the way.
Kinda like this girl I know. (IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif) |
DanT |
and your point is? (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
Actually ads quite a bit of stiffness to the chassis (cabin area). Mine will be installed with large backing plates on both sides, to reinforce the pan. In our PCA region cars with certain modifications require roll bars, to be allowed to participate in Time Trials. |
Joe Ricard |
I guess the point is there is nothing gained in a 914 with that type of bar. No rigidity, I hope we never find out but if the car rolled over I would suspect the bar would cave in at the longs bending either forward of aft.
Adding the petty bar which I believe goes to the center tunnel would prevent some of that???? |
DanT |
I have seen 3 914s roll over in the last 15 years of TTing. In reality the car is stronger than the bar. In all three the targa bar held so well, the top never came into contact with the bar let alone cause any distortation of the roll bar. The part that really needs help is the windshield header....that would be your full cage..
The car is noticably stiffer with the roll bar in place and the petty bar attached. I am speaking from experience with such a bar in a 914 and 914-6. |
jhadler |
Long term tinkerer... ![]() ![]() ![]() Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 ![]() |
From a strictly compettive standpoint, a straight up-and-down roll bar doesn't doo too much to stiffen the chassis. What it does do though, is add additional support to the existing roll structure of the car to prevent it from collapsing on you in the event of the car going "turtle".
In order to get some good chassis rigidity, it to have the bar tie into more points of the car. Even four points would get you some better stiffness from two points... Most sanctioning bodies don't want you on the track without some form of roll protection. In SCCA Time Trials, you can play without a bar, but if you want harnesses (other than the factory 3 point belt), you HAVE to have a good roll bar... -Josh2 |
hmeeder |
Dante's Sportscar ![]() ![]() Group: Members Posts: 352 Joined: 21-November 04 From: San Diego, CA Member No.: 3,154 ![]() |
Aaron;
Here's a boly in Autopower bar with the removable cross brace installed in my car. Read the rule book carefully. If you will be running PCA in SoCal there are some changes for 2006 and they have added the phrase "roll bars must be braced" (p21, section XIV paragraph D) I asked our safety tech (and one of the guys who writes the rules for zone 8 among others) what that means and he says that for it to be a legal bar it must be tied to the floor in 4 places. A petty bar won't even do the trick. Basically, the bar needs to be triangulated to a point forward of the seat on both sides of the car. Of course, I installed my bar before learning of the rule change. Looks like I will need to do some welding! Zone 8 Rules 2006 Attached image(s) ![]() |
Racing916 |
Member ![]() ![]() Group: Members Posts: 341 Joined: 16-October 04 From: Binghamton, NY Member No.: 2,959 Region Association: North East States ![]() |
I was thinking about adding a roll bar and I came across this webpage that sells them for 914's and there is a few types, also they are PCA and SCCA legal.
Steve www.IOPortRacing.com |
DanT |
IOPORT is in Norcal....they sell Autopower bars IIRC. Roll bar is about $400 new.
Lo-Fi Version | Time is now: 9th July 2025 - 01:49 PM |
