Door window and seal aren't aligned, how to fix it? |
DougC |
Feb 8 2006, 09:49 AM
Senior Member Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 |
My driver's side door doesn't close very well because the glass does not seat into the rubber seal on the "B" pillar. How can this be corrected, it's off by quite a bit. thanks.
Doug C |
freezing14 |
Feb 8 2006, 09:55 AM
freezing14 Group: Members Posts: 435 Joined: 21-June 04 From: brockville , Ontario, Canada Member No.: 2,233 |
first thing first,, have you checked you longs,, do the big butt test to see if the car flex,, if it does not ,, then it is just a matter of adjusting the window,, just remove the door panel and you will see the adjustment,screws,
redshift |
Feb 8 2006, 09:58 AM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
Uhh.. B pillar? The back?
Take the seal out, look at the mounting of the thingy.. Please, be specific. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) M |
SirAndy |
Feb 8 2006, 11:10 AM
Resident German Group: Admin Posts: 41,676 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
post a pic ... if the gap is too big, you got some other problem. longs rotted, car made out of two halves, something along those lines ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
DougC |
Feb 8 2006, 11:49 AM
The longs are in really good shape, some of the best I've seen... nice and clean. Don't have a picture of them handy though. I think this issue popped up after I removed, painted and replaced the center metal strip (divides the triangle window from the main window) the back seal unit wasn't installed at the time though. But it doesn't look like there is much adjustment to the long metal dividing piece at the bottom of the door shell.
Doug C |
freezing14 |
Feb 8 2006, 12:36 PM
there is 2 adjustment for the window,, the one on top ( not really adjustable) and the bottom one,, the best way to do is to close the door with all the screw loose hold the window at the right place and tighten all the bolt, the one fron the bottom only adjust invard/ outward,, you might have to "" ovalize"" some holes
DougC |
Feb 8 2006, 01:30 PM
The adjustment screw on the bottom is the one for the window "dividing" piece that I was talking about or is it something else? Yep, that hole ovalizing is probably what I'll need to do.. thanks
Doug C |
neo914-6 |
Feb 8 2006, 01:43 PM
neo life Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
Doug,
I have mine torn apart for my mods so I know what you're talking about. If all you did was remove and replace the rail at the triangular window that shouldn't have affected the b-pillar alignment much. The rail at the lockside of the door should be parallel and you'd have problems rolling your window up and down if it is not. Pics would be helpful. |
DougC |
Feb 8 2006, 01:50 PM
Thanks guys, I'm going to take a good look this evening at the areas you pointed out and I'll shoot some pics if it looks too confusing - thanks!
Doug C |
Eric_Shea |
Feb 8 2006, 01:57 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
If you're 'ovaling' holes, somethings wrong.
You can adjust the frame as mentioned or, it could be that the seal on the B pillar is off for some reason. You would have to take the seal out and adjust the track and then slide the seal back in. Use sylicone spray if you have to go that route. |
Lo-Fi Version | Time is now: 8th June 2024 - 06:50 AM |
