5-Lug 911 Conversion, Caliper differences? |
Spoke |
Feb 8 2006, 04:43 PM
Jerry Group: Members Posts: 6,989 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I'm doing a 5-lug conversion for my new 914 and need some help understanding the differences in front 911 calipers. I've seen "A", "M", and "S" calipers referred to. What's the difference? Which one(s) should I try to get? Lastly, anybody got a set of front struts/rotors/calipers?
Thanks, Spoke PS: If this topic has been covered before, please forward the link to me. |
TimT |
Feb 8 2006, 04:53 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
A & S are the same sized caliper, S is aluminum, A is steel (iron), the aluminum calipers flex under heavy braking, also the A & S have 3.5" mounting bolt spacing. These have a larger pad than the M
M calipers have a smaller pad than the A & S, are iron bodied, and have 3.00" mounting bolt spacing. Any of those calipers will work fine, S calipers command a premium I have a comlplete 911 front end M calipers with vented discs ( this was from a 911 T with S package) |
Aaron Cox |
Feb 8 2006, 05:09 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
QUOTE(TimT @ Feb 8 2006, 03:53 PM) A & S are the same sized caliper, S is aluminum, A is steel (iron), the aluminum calipers flex under heavy braking, also the A & S have 3.5" mounting bolt spacing. These have a larger pad than the M M calipers have a smaller pad than the A & S, are iron bodied, and have 3.00" mounting bolt spacing. Any of those calipers will work fine, S calipers command a premium I have a comlplete 911 front end M calipers with vented discs ( this was from a 911 T with S package) couldnt have summed it up better meself... i find that M calipers with an agressive pad are more than adequate to make my car stand on the nose....... S calipers are $$$$$$$$$$$$$$$ An m caliper front end is anywhere from 200- 500 an A caliper front end is 500-800 Add a couple hundred to the above for S calipers.... |
Eric_Shea |
Feb 8 2006, 07:55 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) What she said...
You might want to equate it to cars and struts while your searching. Boge struts came with the 911T. They're the most common out there in the early car range (69 through 73). The had the 3" mount spacing and hence the M-Calipers Koni and later Bilstein struts 'generally' came on various 911S models and could be ordered as an option. The S models in those years had the S-Caliper. They're aluminum and a bit pricey but you can find rebuildable examples for $100-200 each. I've never felt the flex but... others have. Some 914-6/GT's came with them and given the power ratio on a 76 930 (which also had them) They are good for 914's up to 240-250hp. DaveP had a friend who tried them all and said that anything beyond an S-Caliper (A-Caliper as well as an example) is overkill. Later (911 and 911SC) front ends had the A-Caliper. As described above, same pad size (but not depth) as the S-Caliper. I like the earlier front ends as they're set up for through-body bars. That being said the late model front ends can be retro-fitted with the U-Tabs and all should be fine. And, to add to that, if you're just looking at struts and not complete front ends... you don't have to worry. If you're going the 'strut only' route you'll need to make sure your ball joints match. E. |
Eric_Shea |
Feb 8 2006, 07:58 PM
You might want to be careful... if you stop too fast, you might get rear-ended! (IMG:http://www.914world.com/bbs2/html/emoticons/w00t.gif)
TimT |
Feb 8 2006, 08:10 PM
its not that you really feel the caliper flex, you find out the calipers were flexing when you pull the pads and they have a wierd type of wear |
brp914 |
Feb 8 2006, 08:14 PM
Unregistered |
QUOTE(Aaron Cox @ Feb 8 2006, 03:09 PM) QUOTE(TimT @ Feb 8 2006, 03:53 PM) A & S are the same sized caliper, S is aluminum, A is steel (iron), the aluminum calipers flex under heavy braking, also the A & S have 3.5" mounting bolt spacing. These have a larger pad than the M M calipers have a smaller pad than the A & S, are iron bodied, and have 3.00" mounting bolt spacing. Any of those calipers will work fine, S calipers command a premium I have a comlplete 911 front end M calipers with vented discs ( this was from a 911 T with S package) couldnt have summed it up better meself... i find that M calipers with an agressive pad are more than adequate to make my car stand on the nose....... S calipers are $$$$$$$$$$$$$$$ An m caliper front end is anywhere from 200- 500 an A caliper front end is 500-800 Add a couple hundred to the above for S calipers.... huh? whuzzat? one willingly pays a premium to have his calipers flex!? Isn't the whole idea behind a monoblock caliper to have less flex? And it being aluminum having the benefit of better heat dissipation and less unsprung weight? as far as stopping quickly, when cold a regular 914 caliper will stop just as fast as an "m" or even an "a". The question is fade resistance and modulation. Or are you saying there are tires out there so sticky that the caliper is overwhelmed? but even then, this can be compensated for with pad selection. |
TimT |
Feb 8 2006, 08:21 PM
There is a world of difference between a 60's vintage aluminum S caliper, and a 00 vintage monoblock, there is no comparison. The S calipers are desirable for their lightness, and period correct look to some |
Eric_Shea |
Feb 8 2006, 08:23 PM
He be right as well... which is why with a stock 914, and a 911 front end, the M-caliper is perfectly fine as Aaron eluded to.
The bigger the tire then you might want to look for big-ole calipers. (IMG:http://www.914world.com/bbs2/html/emoticons/dead horse.gif) Buy Tim's 911T front end. |
brp914 |
Feb 8 2006, 08:53 PM
Unregistered |
hey, dont you (IMG:http://www.914world.com/bbs2/html/emoticons/dead horse.gif) me. I invented (IMG:http://www.914world.com/bbs2/html/emoticons/dead horse.gif) !!! (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Allan |
Feb 8 2006, 08:57 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I have "A" calipers...
They are sitting in storage right now. (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) |
Eric_Shea |
Feb 8 2006, 11:16 PM
I do believe it twas I who invented the (IMG:http://www.914world.com/bbs2/html/emoticons/dead horse.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
You'll have to ask Sean (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) It was actually in this thread. (IMG:http://www.914world.com/bbs2/html/emoticons/lol3.gif) |
Cap'n Krusty |
Feb 8 2006, 11:35 PM
QUOTE(Eric_Shea @ Feb 8 2006, 09:16 PM) I do believe it twas I who invented the (IMG:style_emoticons/default/dead horse.gif) (IMG:style_emoticons/default/biggrin.gif) You'll have to ask Sean (IMG:style_emoticons/default/laugh.gif) It was actually in this thread. (IMG:style_emoticons/default/lol3.gif) IIRC, M calipers use the same pads as the ones that came stock on your teener. The Cap'n |
Eric_Shea |
Feb 9 2006, 12:05 AM
And your point is? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
craig downs |
Feb 9 2006, 12:27 AM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
So does this mean with the M caliper struts do you have to use the older style ball joints with the thru bolts
Spoke |
Feb 9 2006, 07:45 AM
QUOTE(Eric_Shea @ Feb 8 2006, 08:58 PM) You might want to be careful... if you stop too fast, you might get rear-ended! (IMG:style_emoticons/default/w00t.gif) Thanks, I needed my morning chuckle. If I don't get an entire 911 front end with torsion bars, A-arms, and sway bar, I'll use the t-bar, a-arms, and sway bar on my 71 914 which are from an 81 Carrera. From the feedback, it seems that A calipers are good, followed by M calipers, with S being the best. Spoke |
Eric_Shea |
Feb 9 2006, 08:16 AM
No. I believe the 911 switched to the newer style ball joints 1-2 years before the 914. You just have to wcth for mis-matches and now the differences. |
Lo-Fi Version | Time is now: 3rd June 2024 - 10:15 AM |
