Curses!, Rust in an unexpected place! |
Bertus |
Feb 11 2006, 12:57 PM
Member Group: Members Posts: 222 Joined: 2-May 05 From: Lexington, KY Member No.: 4,021 Region Association: South East States |
Ok so I am preping the inside of my car, removed the interior getting rid of a little bit of surface rust on the floorpans, no big deal. I contemplated leaving the sound proof pad on the interior fire wall. Then I decided that would be half-ass so I pull it off. And there is a bid friggin hole behind the drivers seat! It looks to be a weld seam that has rusted, a good 10" off of the floor pan, seems like a very strage place to rust! Anybody else encounter this, can I weld a patch or will I need to replace a larger piece?
ARRGH! (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) Thanks Attached image(s) |
tat2dphreak |
Feb 11 2006, 12:58 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
damn sorry to hear that... Resto design has the back piece, or you can fab a patch to weld in... (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
SLITS |
Feb 11 2006, 01:00 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Water leaking down from a poor engine hatch to rear window seal...saturates the "sound pad". Haven't seen one exactly like that, but have seen numerous pinholes in that area and completely rusted out "firewall".
A piece can be cut from a "donor" car and welded in. |
rhodyguy |
Feb 11 2006, 01:01 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
usually the pass side is worse (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) . keep looking.
k |
Bertus |
Feb 11 2006, 01:29 PM
Luckily the passanger side seems pretty solid, I plan on dropping the engine soon so I should know the whole story soon. What do you guys use to cut out a donor piece? Grinder with a cutting wheel? Thanks |
tat2dphreak |
Feb 11 2006, 01:43 PM
grinder is ok, but harbor freight has "body saws" that hook up to a compressor and will make short work of it... |
Lo-Fi Version | Time is now: 1st June 2024 - 12:10 AM |
