Manual vs. Hydraulic Clutch Actuation, Converting over to hydraulic actuation. |
GTPatrick |
Mar 4 2006, 01:00 AM
Member Group: Members Posts: 245 Joined: 8-September 05 From: Memphis, Tn. Member No.: 4,768 Region Association: None |
Has anyone tried to convert the manual clutch cable over to hydraulic clutch lines before ??? Has this been discussed before ??? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
As to the master & slave cylinder , it seems that at the front end where the clutch pedal is , it could possibly be done but back at the clutch housing it would be hard to come up with a sane workable design . (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) Present day race cars and road cars have hydraulic lines instead of cables so why not the 914 ??? Anyone have any input on this ??? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/type.gif) |
messix |
Mar 4 2006, 01:04 AM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
there are hydrualic throw out bearings. not sure about fitting one up to 901's. worth some research though.
GTPatrick |
Mar 4 2006, 01:08 AM
With the hydraulic actuation, you don't have to worry about adjusting the clutch cable, stretch of the line etc. . The problem that I see is that to mount the master cylinder back on the clutch/transmission would be possibly be a biatch of a conversion . Not unless someone has done it before without too big a hassle . (IMG:http://www.914world.com/bbs2/html/emoticons/popcorn[1].gif)
TravisNeff |
Mar 4 2006, 01:50 AM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
Airsix has done this, maybe pics in his blog?
lapuwali |
Mar 4 2006, 02:42 AM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
It has been done more than once and more than one way. Cobbling up the pedal box mount is the most challenging part of it. Rich Johnson, I think, sells the parts to do one.
While you don't have to worry about adjusting the cable or dealing with a broken cable, you do have to worry about leaky master and/or slave cylinders. No free lunch. Indeed, I've generally had more trouble with hydraulic clutch setups than cable clutch setups. |
type47 |
Mar 4 2006, 05:59 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
vanagons (80-91 vw vans) have hydraulic clutches, maybe some of those parts could be used.
IronHillRestorations |
Mar 4 2006, 07:14 AM
I. I. R. C. Group: Members Posts: 6,726 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I may have had the first set up, and paid for the R&D for the kit that Rich sells. It uses a 928 master cylinder, and an aftermarket pull type slave cylinder made by CNC (a VW/buggy supplier). It also required a custom weld in bracket to mount the master cylinder, and a bolt on bracket for the slave cylinder. You also have to drill a hole for the m/c push rod.
The master cylinder was actuated directly off the clutch cable pivot up front, with a bolt and a heim joint on the m/c push rod. I ran teflon stainless braid brake line through the cable tube for the hydraulic line. The brake resevior supply line was spliced with a T to supply the system. The first slave cylinder went south early from heat exposure, so I wrapped the heat exchangers with Thermo-Tech header wrap, and that slave (as far as I know) has been on the car, problem free for about ten years now. |
wbergtho |
Mar 4 2006, 07:23 AM
Senior Member Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 |
Do a search for hydraulic clutch and you'll see all the conversions you'll want to see. Some were ingenious...some were overkill. I like the guy who can make a clean conversion without killing himself over a month's time (there are a few likw that too). USE THE SEARCH ENGINE! IT WORKS. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
GTPatrick |
Mar 4 2006, 01:25 PM
Thanks for the info . (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif)
turbo914v8 |
Mar 5 2006, 09:29 AM
Member Group: Members Posts: 373 Joined: 26-July 03 From: Canada Member No.: 952 |
I did this conversion on my 914, but have since moved up to the Tiltion 3 pedal set up. I have pictures of different installs and I also have for sale a partial kit. PM me if your interested.
rick 918-S |
Mar 5 2006, 09:41 AM
Hey nice rack! -Celette Group: Members Posts: 20,478 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Post the photos in your blog so we can view them here. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
Lo-Fi Version | Time is now: 4th June 2024 - 03:56 PM |
