Sway bar rates for rear 914 bar??? |
Mueller |
Feb 19 2003, 06:38 PM
Anyone have this number or know the dimensions (bar dia, and distance from the centerline of the bar to the centerline of the mounting point on the rear shock) so that I can figure it out?
campbellcj |
Feb 19 2003, 06:42 PM
I can't Re Member Group: Members Posts: 4,550 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I have a welt 16mm rear bar sitting in my garage if that would help.
airsix |
Feb 19 2003, 06:56 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
QUOTE(Mueller @ Feb 19 2003, 04:38 PM) Anyone have this number or know the dimensions (bar dia, and distance from the centerline of the bar to the centerline of the mounting point on the rear shock) so that I can figure it out? Hey Mike, I've got a stock bar hanging on the wall in the garage. I'll throw the calipers around it tonight and let you know the diameter. I'll run a tape from end-to-end too. -Ben ps - thanks again for the door stay. pps - Like my avatar? That's my hunt'n partner. We really terrorized the bunnies Saturday. We've been working together since November and he still doesn't have a name. Anybody got any ideas? |
Mueller |
Feb 19 2003, 07:12 PM
Hey Ben....
Neat bird.....not too far from where I live I see some guy in the morning training his hawk/falcon..... |
drew365 |
Feb 19 2003, 07:14 PM
These are the good old days! Group: Members Posts: 2,004 Joined: 29-December 02 From: Sunny So. Cal. Member No.: 37 |
My rear Welt is 16mm also. Don't know the other dimensions. I'll be under it tonight, if no one else posts I'll grab a tape.
Mueller |
Feb 19 2003, 07:28 PM
The dimensions I am looking for are A or B,
it depends on which portion of the bar on the top area that gets mounted to the car....I have no swaybar to figure that one out (IMG:style_emoticons/default/smile.gif) |
jonwatts |
Feb 19 2003, 07:55 PM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
QUOTE(airsix @ Feb 19 2003, 04:56 PM) That's my hunt'n partner. We really terrorized the bunnies Saturday. We've been working together since November and he still doesn't have a name. Anybody got any ideas? Mr. Peepers |
Bleyseng |
Feb 19 2003, 08:06 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
A=12"
16mm bar Geoff |
Alfred |
Feb 19 2003, 08:11 PM
Unregistered |
QUOTE(airsix @ Feb 19 2003, 04:56 PM) QUOTE(Mueller @ Feb 19 2003, 04:38 PM) pps - Like my avatar? That's my hunt'n partner. We really terrorized the bunnies Saturday. We've been working together since November and he still doesn't have a name. Anybody got any ideas? (IMG:style_emoticons/default/confused24.gif) Killer? Alfred |
ChrisReale |
Feb 19 2003, 08:22 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
Hi Air Six, where abouts do you live in Eastern wash? I might be cruising around there in my 914 when the weather clears up. Id love you see your falcon in action if possible....
Jeroen |
Feb 19 2003, 08:32 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Darn, it's cold in the garage...
The bar diameter is 16mm Dimension A = 280mm (center of the bar to the center of the droplink mounting eye) Dimension B = 320mm (center of the bar to the center of the droplink mounting eye) HTH, Jeroen |
Tony C |
Feb 19 2003, 11:41 PM
Master of Fire and Metal Group: Members Posts: 273 Joined: 27-December 02 From: Bay Area, CA, USA, Earth Member No.: 25 |
Mike, Also keep in mind when figuring out spring rates, the endlinks bend, the bushings compress, and "heat treating" varries. Except for the "speedway engineering" type bars it is very hard to get very close to the real installed spring rates when trying to calculate the spring rate.
-Tony |
airsix |
Feb 20 2003, 01:34 AM
Guess I should have stayed home Saturday and cleaned the garage. I can't find my caliper or my metric tape. Sorry you'll have to convert I guess.
A = 11 3/8" (from bar center to center of pivot ball) B = 12 15/16" (from bar center to center of pivot ball) Distance between pivot balls = 34 7/8" (measured to center of balls) Overall width (elbow to elbow) = 43 7/16" Distance between chassis mount points (based on bushing wear marks) = 39 1/2" Hope that helps. -Ben |
JWest |
Feb 20 2003, 07:27 AM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
Just to clarify, it mounts at the "A" portion so that is the relevant dimension.
Lo-Fi Version | Time is now: 12th June 2024 - 04:29 AM |
