> GRRRRR
-P-
post Sep 13 2003, 05:40 PM
P-Factor
Well it started out as a nice day replacing the strut inserts on my car. Did the 1st side, and after realizing how it all worked realized you didnt need need to pull the strut off to replace the insert moved on to the second. 30 minutes later while giving everything a once over on the second side I noticed a bit of play in the strut when shaking it making sure everything was secure.. I though for a moment and didnt remember putting the collar on the strut insert. So I check the box and there is none to be found. I read the box (which was obviously opened before) and saw "Def" written on it. The strut had never been installed but the collar was missing.... So no driving this weekend and early this week until I contact Pelican. Needless to say I am a bit pissed as I already had to settle for the Bilsteins after they called a couple days past when the order was placed and asked what else I would settle for because they were out of Konis sports....
I will call them 1st thing Monday and I am sure they will make it right.
On a side note, every single Koni that I took off, both front and back, was leaking, and leaking bad.
Lessons learned:
Pipe wrenches kick ass
Check the boxes for all the pieces before you start.
The second side on a project always goes 100% quicker.
mharrison
post Sep 13 2003, 05:47 PM
Why do I bother????
Gee this sounds like my life!!! It'll be worth the wait when it's all done though....(that's what I always tell myself!)
-P-
post Sep 13 2003, 05:48 PM
P-Factor
QUOTE(mharrison @ Sep 13 2003, 05:47 PM)
That is what kept me from throwing things at people near by (IMG:style_emoticons/default/ar15.gif)
TimT
post Sep 13 2003, 07:13 PM
retired
interesting... there are a couple of negative threads about pelican on pelican today.... interesting
Aaron Cox
post Sep 13 2003, 09:53 PM
Professional Lawn Dart
i almost did the same thing. paragon had koni's- and they were a little cheaper. (IMG:style_emoticons/default/boldblue.gif)
seanery
post Sep 13 2003, 10:22 PM
waiting to rebuild whitey!
DUDE, you're in Texas! Buy from Jason at Paragon!
They had the best prices on yellows, too!
Paragon Web
-P-
post Sep 16 2003, 09:37 PM
P-Factor
Pelican made good on their blunder as expected and I installed the struts tonight after they next day aired me a new one. It almost feels like a new car (IMG:style_emoticons/default/smile.gif).
Now to tighten up the steering, then shifter, then brakes.
Brad Roberts
post Sep 16 2003, 11:36 PM
914 Freak!
You should have never accepted the Bilsteins... they work great (and I use them.. but only when the customer wont pop for adj. Koni's)
Not sure if you asked the BBS or not.. but I would have told you that you didnt need to remove the strut.
B
-P-
post Sep 17 2003, 03:00 PM
P-Factor
QUOTE(Brad Roberts @ Sep 16 2003, 11:36 PM)
B
Yeah I know, but whats done is done. The Bilsteins seem fine for my use.
The brake system got a good flushing though (IMG:style_emoticons/default/smile.gif)
- Lo-Fi Version Time is now: 19th July 2025 - 04:47 AM
