914 Starter woes, HELP |
gr_elvis |
Apr 13 2006, 11:21 PM
Newbie Group: Members Posts: 27 Joined: 8-September 05 From: Grand Rapids MI Member No.: 4,769 |
Is there a difference in starters from 1.7 1.8 and 2.0 for the 914? My flaps is trying to tell me I need a starter that has no nose cone the gear just sticks out the back on the shaft and when I put that one in it didnt work nor was it anything like The one that came out of the car, So I oredered the one for 2.0 and it looks right but sounds like it is jamiing in the flywheel and staying engaged . Makes a horrible noise. I need to know what to do next HELP!? Please ASAP (IMG:style_emoticons/default/confused24.gif) Thank you ...thank you very much
McMark |
Apr 13 2006, 11:41 PM
No difference. But there is a difference between Bus and 914 starters.
GWN7 |
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
I had a FLAPS try and sell me a starter for a automatic 914....it was listed in their system as the right one for the 914......only by cross referencing the numbers did we figure out what was wrong with their listings.....all are the same
kenpolives |
Apr 14 2006, 03:34 AM
Member Group: Members Posts: 167 Joined: 31-December 03 From: Albany NY Member No.: 1,479 |
Could be the flywheel, broken teeth etc $$$$$$$ hope not
smooth_eddy |
Apr 15 2006, 01:01 AM
Senior Member Group: Members Posts: 535 Joined: 13-November 04 From: Seattle Member No.: 3,102 |
Man, if you are going to buy a new starter; Do yourself a favor and buy the mini starter they sell on eBay. I got mine delivered to my door for under a hundred bucks. It's way better and no more hot start problems. It is the Nippondenso gear reduction motor. It just bolts in place of the old one.
SLITS |
Apr 15 2006, 07:49 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
The starter that most FLAPS try to push is wrong. Their catalogs have been wrong forever. They will tell you that it calls for SR15X / Lester 16450 (Bosch Rebuilt number / Lester Catalog number)..and it is wrong.
The starter you need is a SR17X / Lester 16300, also listed as the "automatic" starter. You can use and SR68X / Lester 16426 which was fitted to the early 911. It has about twice the horse power. Correct Starter On the above page the starter at the top is correct. The next one is NOT. |
gr_elvis |
Apr 15 2006, 10:37 PM
The starter that most FLAPS try to push is wrong. Their catalogs have been wrong forever. They will tell you that it calls for SR15X / Lester 16450 (Bosch Rebuilt number / Lester Catalog number)..and it is wrong. The starter you need is a SR17X / Lester 16300, also listed as the "automatic" starter. You can use and SR68X / Lester 16426 which was fitted to the early 911. It has about twice the horse power. Correct Starter On the above page the starter at the top is correct. The next one is NOT. |
So.Cal.914 |
Apr 16 2006, 12:52 AM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
They have done the same thing to me . I finally got smart and took the starter with me and had them match it up. No more problem.. (IMG:style_emoticons/default/smoke.gif)
SLITS |
Apr 16 2006, 08:40 AM
Tobra |
Apr 16 2006, 10:08 AM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
103 bones, for the 911 starter, which has like twice as power as the $60 one. That is a direct bolt on right, just the 1.5 hp version, wonder if Napa or Autozone would have that starter in stock, there are a heck of a lot of aged yuppies around here with old P cars
SLITS |
Apr 16 2006, 10:29 AM
You just have to ask for the right one...the 1.5 kW (911 starter) spins a type 4 real nice.
But for the same price on The 'Bay, you can get one of the japo gear reductions w/ modified nose...lighter, 2 HP and spins the engine like crazy |
Trevorg7 |
Apr 16 2006, 10:54 AM
Senior Member Group: Members Posts: 1,242 Joined: 7-December 04 From: Highland Village, TX Member No.: 3,241 Region Association: Southwest Region |
QUOTE Man, if you are going to buy a new starter; Do yourself a favor and buy the mini starter they sell on eBay. I got mine delivered to my door for under a hundred bucks. It's way better and no more hot start problems. It is the Nippondenso gear reduction motor. It just bolts in place of the old one. I agree. I replaced mine with the same one and it bolted right on and works great. T |
Joe Bob |
Apr 16 2006, 11:15 AM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
BTW....no such thing as a NEW 914 starter. They are all rebuilt/renewed and only to the tune of...hey it works.
The SR68X is double the hp and will last longer as it's less of a load with the T4. The ones sold at the local Kragen and Pepe boys come with a free replacment, free tow if stranded but don't cover costs on labor....trust me....they DO fail....early and often. "I" have two sitting on the shelf that were actually REBUILT using NEW parts at my local shop. Save your cores....... |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:43 AM |
