Eddie914 |
Unregistered ![]() |
In preparation for installation of the 3.2 into the teener, I'm cleaning up a few items: New SS fuel lines, welding the broken clutch tube, front oil cooler thermostat and brake proportioning valve.
I'm planning on replacing the stock proportioning valve with a "T" and installing an adjustable valve. What type/brand of valve do other teener owners use? The Good? The Bad? The Ugly? Lever type ... Wilwood? Knob type ... Wilwood or SBC or ? Thanks Eddie |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
What brakes are you using?
JWest |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None ![]() ![]() |
Rough_Rider |
Smurf Zone ![]() ![]() ![]() Group: Members Posts: 525 Joined: 16-August 04 From: Beaverton, OR Member No.: 2,547 ![]() |
I've the lever style one. It works fine however it only has 5 or 6 detents. Plus when adjusting more to rear the feel goes from a positive click to loose. A couple of times on bumpy track the lever has jumped to full rear brakes, which lead to rear lockups.
IMO go with the twisty type. so long as it holds its position. |
Eddie914 |
Eric,
911SC front & rear calipers and rotors Porterfield R4 pads Front: 225/50/16 on 16 x8 Rear: 245/45/16 on 16 x 9 Thanks Eddie |
Eric_Shea |
You may not need one with that set-up but you probably have enough rear brake to warrant one if you want one... I kinda like the set-em and forget-em kind that can take the place of the T.
I use a T with a similar set-up. |
Eddie914 |
Thanks All!
Just ordered a "T" and adjustable proportioning valve from JWest Engineering. Eddie |
JWest |
Lo-Fi Version | Time is now: 10th June 2024 - 11:57 PM |
