nine14cats |
Bill Pickering -- 914-6 GT aka....Leeloo ![]() ![]() ![]() ![]() Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None ![]() |
I've torn down the 2.7 I bought for The Beast. All the way down. Now I'm disassembling the camshalft housing from the heads. I'm using Wayne's Pelican book and it says to take the valve rocker arms out before separating the heads from the cam housings.
So I'm supposed to use a 5mm allen on one end and a 8mm allen on the other. When I put them in I cannot get the rocker nuts / bolts to move at all. I don't want to force it. Anyone have experience pulling these things? JP? Bueller? Anyone? Anyone? I'll see if I can snap a pic if I can find the digital camera. Bill P. |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,438 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
try loosening the 5mm end ,holding the 8mm steady.
the 5mm end is an allen bolt passing thru the rocker shaft ,it will loosen before the 8mm end will. |
nine14cats |
Hi Jeff,
The book mentions this as well. My 5mm flexes in half basically and won't move it. I don't have enough room in the housing to fit my socket wrench with the 5mm allen. Should I just keep twisting? It sure looks like I'll snap my 5mm allen. Thanks, Bill P. |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
Jeff said it, that's the way they come apart.
There's only supposed to be around 13 ft/lbs torque on those suckers. A small cheater bar on your allen wrench. I use an inch/pound torque wrench and a home made socket/allen head for the in&out. |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Hi Jeff, The book mentions this as well. My 5mm flexes in half basically and won't move it. I don't have enough room in the housing to fit my socket wrench with the 5mm allen. Should I just keep twisting? It sure looks like I'll snap my 5mm allen. Thanks, Bill P. The ONE item I recommend from Harbor Freight is the ball end allen wrench (AKA Allen Key) set. Available in both metric ans US, they're great. Strurdy, retain their shape, and are a handy size. Reasonably priced, too. I don't see the sets I have in the online catalog, but here's a number that looks like it might be good: ITEM 41003-3VGA. Go for it! BTW, I use them with part of the short leg cut off for less flex in the tool under load. The Cap'n |
sixnotfour |
susan says,(as well as JP) 3/8 drive 5mm stubby with inch pound torque wrench, makes life easy, no flex ,as Kap'n mentions
Attached image(s) ![]() |
nine14cats |
Thanks Guys,
Looks like I'll be tool shopping tomorrow. Bill P. |
Lo-Fi Version | Time is now: 17th June 2024 - 09:21 AM |
