> Thermostat Repair ..., can it be done?
vesnyder
post Apr 27 2006, 06:44 AM
Just purchased a thermo from a fellow 914Club member and it appears that it does not work? I've done the hot water test and the thing does not expand at all? It appears to be in good shape so I was wondering if these can be repaired? Guidance is appreciated!
davep
post Apr 27 2006, 08:24 AM
914 Historian
I have not heard of them being repairable. It would be difficult to find the leak, and repair it.
tat2dphreak
post Apr 27 2006, 08:40 AM
stoya, stoya, stoya
someone tried to fix one for me, but no go... you would need to braze it, but when you heat the thing it expands more and more, then coolr and contracts much too fast for the solder to hold... good luck...
call HPH when you give up (IMG:style_emoticons/default/wink.gif)
he has them for a good price...
tyler
post Apr 27 2006, 01:13 PM
Considering the price of a new one, it would never be worth the risk of having one mess up. They should even be replaced when they get old....my opinion
Hammy
post Apr 27 2006, 02:42 PM
mr. Wonderful
What's the price of them new?
LvSteveH
post Apr 27 2006, 03:02 PM
I put the Poor in Porsche
You really need to find out the temp range of expansion and contraction to determine if it works or not. Try putting it in your freezer, then measure. Let it adjust to room temp. (70 deg) and measure again. Finally, try some very hot water. Then you'll have some means of comparison.
My guess is that as long as the bellows contracts sufficiently in the freezer or refrigerator, then it's doing it's job. You don't need the flaps closed at 70 degrees. As long as they are closed when it's really cold out, they are going to help speed the warm-up process. Maybe someone has exact specs and can shed more light on the subject.
jhadler
post Apr 27 2006, 03:59 PM
Long term tinkerer...
If you only plan on using the car in warm weather, then a thermostat isn't really that important. Leaving it out is also an option. The car may not warm up as quickly when it's cold out, but as far as I know, it's by no means bad for the motor to leave it off. The flaps will close in the safe position, and will give max cooling air to parts that need it.
I ran my car for years without a thrermostat, with no realy problems. Even on cold days, it just took longer for the motor to warm up...
-Josh2
newto914s
post Apr 27 2006, 08:03 PM
What's the word on using a thermostat from other aircooled cars? Namely a type 1.
- Lo-Fi Version Time is now: 7th July 2025 - 05:37 AM
