My front suspension -pics, is this much rust OK? |
Chris Pincetich |
May 1 2006, 11:53 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
First I got the front end up - practice pic post (IMG:style_emoticons/default/smile.gif)
Attached image(s) |
Chris Pincetich |
May 1 2006, 11:55 PM
Then I saw the damage: missing front gravel guard! (I am pretty sure it got left at the mehanic's shop after some other repair) and rusty front cross bar.
Attached image(s) |
Chris Pincetich |
Rusty master cylindr with a raised "20" visible on it
Attached image(s) |
Chris Pincetich |
May 1 2006, 11:58 PM
My front swaybar mount: Weltmeister I think and looks good!
Attached image(s) |
Chris Pincetich |
May 2 2006, 12:05 AM
Now for the questions:
1) Can you see the thin metal piece near the top of the wood block on my jack? It looks like the remains of something that was thin, metal, and rusted off. What was it??? 2) Is the pitting of rust on the round cross member severe? Should I work on wire brushing it off, acid prep, and paint it? Maybe look for a replacement?? 3) Same questions with the master cylinder: too much rust to buff out and keep it, or get a new one? 4) Can anyone confirm the sway bar is Weltmeister? Is the "22 mm" the width of the square end of the bar, or do I need to measure the OD of the actual bar inthe middle to ge the measurement ofr the size? I have only been driving a month w/o the gravel cover - but a lot of that was in the rain. My car has rust issues - some fixed some monir and now this! (IMG:style_emoticons/default/dry.gif) No - I am not looking to go to a 5-lug suspension or anything like that. However, getting a bargain budget suspension set-up at the Parts Heaven swap then getting it all rebuilt and coated in my garage for a full swap would be interesting....any advice is greatly appreciated (IMG:style_emoticons/default/beerchug.gif) |
John |
May 2 2006, 12:52 AM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
QUOTE 1) Can you see the thin metal piece near the top of the wood block on my jack? It looks like the remains of something that was thin, metal, and rusted off. What was it??? That is what remains of your gravel shield. QUOTE Should I work on wire brushing it off, acid prep, and paint it? Yes QUOTE 3) Same questions with the master cylinder: too much rust to buff out and keep it, or get a new one? If it is not leaking, I wouldn't worry about the master cylinder. More importantly, how is your pedal cluster? That is something worth rebuilding/refinishing. QUOTE do I need to measure the OD of the actual bar inthe middle to ge the measurement ofr the size? The round portion will be the same diameter as the middle. Yes, I believe it is a weltmeister. |
Chris Pincetich |
May 2 2006, 01:26 PM
Thanks JOHNMAN! (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 2nd June 2024 - 01:43 AM |
