wbergtho |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 ![]() |
I have less than a 1000 miles on a new 930 box and clutch. The T.O. bearing seems dry and toasty and the guide tube looks well worn and "lumpy" on one side only. I may have had preload on the T.O. bearing when i first set the trans up and drove 200-300 miles. I eventually went to a hydraulic clutch and allowed a small air gap @ the slave to prevent preloading the T.O bearing. It apparently doesn't take long to toast these parts. I'm hoping my box is still fine.
Anyone with any experience (good/bad)...please chime in. For now, I believe I will replace these parts...cross my fingers...and reassemble. This is becoming such a pain in the ass...that I'm no longer having any f--- (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/dry.gif) ing fun with this car. It's just a dreaded feeling to drive it...knowing that I'll be putting it up on jack stands to repair and spend more godamn money! Bill Attached image(s) ![]() |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Your picture sucks. LOL
I see NO grease on it (you could have cleaned it off before crappy pic) Also: Replace that piece EVERY TIME you do a clutch job. I use a high temp wheel bearing grease (syn) and put some in the inside of the TO bearing and some on the guide tube. FYI: replace the "fork" also. BUT>> look at the one you pull off. They have to be clearanced before you install the new one. All of these are wear items that should be replaced during every clutch job.. and typically people cheap out and dont do it, or dont know that they should be replaced. B |
drive-ability |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 ![]() |
I have less than a 1000 miles on a new 930 box and clutch. The T.O. bearing seems dry and toasty and the guide tube looks well worn and "lumpy" on one side only. I may have had preload on the T.O. bearing when i first set the trans up and drove 200-300 miles. I eventually went to a hydraulic clutch and allowed a small air gap @ the slave to prevent preloading the T.O bearing. It apparently doesn't take long to toast these parts. I'm hoping my box is still fine. Anyone with any experience (good/bad)...please chime in. For now, I believe I will replace these parts...cross my fingers...and reassemble. This is becoming such a pain in the ass...that I'm no longer having any f--- (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/dry.gif) ing fun with this car. It's just a dreaded feeling to drive it...knowing that I'll be putting it up on jack stands to repair and spend more godamn money! Bill Bill, I went through a similar situation, I too preloaded the T/O bearing for a time and did some damage to my guide tube. I think having the pre-load held the T/O against the guide tube and caused the marks. The key is free-play, once I gained some things seem to be working well. Consider your self a bit lucky, before I learned I trashed the thrust bearing in my engine. I had to do a lower-end rebuild before addressing the clutch issue. I also set up some springs to help keep everything balanced concerning the clutch fork. One spring keeps the free-play gap when the clutch is engaged and the other balances the weight of the heavier fork body and slave system. I also make sure the clutch pedal is held away from applying any pressure on the system at rest. I've felt your pain (IMG:style_emoticons/default/smash.gif) (IMG:http://members.cox.net/altjamy/Clutch%20fork%20springs%20.600HANNAH%20AND%20DAD%20046.jpg) |
Lo-Fi Version | Time is now: 11th July 2025 - 04:51 PM |
