So where does this cable go?, Yet another broken gizmo on my 914 |
terrymason |
May 9 2006, 08:45 PM
Member Group: Members Posts: 346 Joined: 23-November 05 From: Virginia Beach Member No.: 5,174 |
Found this during my old change. The wire going down in the picture is not connected to the correct place.
Click to enlarge (IMG:http://img422.imageshack.us/img422/4918/picture0199dl.th.jpg) (IMG:http://img220.imageshack.us/img220/1478/picture0204qz.th.jpg) any idea what it is? |
SLITS |
May 9 2006, 08:49 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Thermostat cable....goes from thermo, round the pulley, up thru the engine tin and ties to your blower housing flapper assembly.
Supposedly controls engine warm up by closing the cooling flaps in the housing until engine is toasty, the opens for full flow to cylinders and oil cooler. |
SirAndy |
May 9 2006, 09:13 PM
Resident German Group: Admin Posts: 41,651 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
schlitz is right. cable for your thermostat. can't see in the pic if the round pulley wheel is missing, but if it is, that might be the reason for your OIL LEAK ...
the bolt that normally holds down the pulley wheels is a *through* bolt. if removed, your case will "vent" large amounts of oil to the enviroment (read, the outside of your motor) ... anyways, cable goes around pulley wheel, straight up through the engine tin to the cooling flappers linkage on top of your engine, front, on the fan-shroud ... (IMG:style_emoticons/default/smile.gif) Andy |
Lo-Fi Version | Time is now: 23rd May 2024 - 07:09 AM |
