Rear End, 914 that is... |
2-OH! |
May 25 2006, 10:05 AM
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
73' Tub is in for final body work...But in his zeal for life, the body guy filled the indention on the outside directly under the rear trunk lock hole ...
Because it's been sooo long since I tore the tub down, I forgot what purpose this area serves... Does anyone have a close up picture of this area... Does anyone know if I need this indention or should I just leave it filled and let him paint it when he paints the tub... Thanks, 2-OH! |
Jeroen |
May 25 2006, 10:16 AM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
If I understand you correctly, those are for the licenceplate lights
Phoenix-MN |
May 25 2006, 10:17 AM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
It's where the wiring comes through for the license plate lights
Paul 73' Tub is in for final body work...But in his zeal for life, the body guy filled the indention on the outside directly under the rear trunk lock hole ... Because it's been sooo long since I tore the tub down, I forgot what purpose this area serves... Does anyone have a close up picture of this area... Does anyone know if I need this indention or should I just leave it filled and let him paint it when he paints the tub... Thanks, 2-OH! |
Allan |
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I think that indent is for routing the license plate light wiring.
Attached image(s) |
2-OH! |
May 25 2006, 10:20 AM
If I understand you correctly, those are for the licenceplate lights Jeroen: I think the license plate lights are on either side of this spot, same height and appearence, but to either side of this one...I will get the Wiring Harness out of the box tonight and see if it is one pigtail or two.. Thanks for the advice... RE |
2-OH! |
May 25 2006, 10:24 AM
Looking at the pictures, it is right between the two shown, directly over the little bracket that digs into my leg every time I pass by the tub and directly below the lock hole...The two on either side are still there...Don't know why he filled the center one but not the other two...
You guys are great...Thanks for the help... RE |
Lo-Fi Version | Time is now: 8th June 2024 - 10:08 AM |
