Main Oil Seal Replacement with engine in car |
pfan12000 |
May 30 2006, 06:01 PM
Newbie Group: Members Posts: 14 Joined: 9-March 05 From: Piscataway, NJ Member No.: 3,734 |
Hi,
Anyone has posted the procedure to replace the (behind flywheel) crank main seal by removing only the tranny and leaving the engine mounted in the car? Are flywheel bolts reusable or should one replace with new ones everytime the flywheel is removed? (IMG:style_emoticons/default/chair.gif) |
Mueller |
May 30 2006, 06:10 PM
one could look at the Haynes manual for guidance (IMG:style_emoticons/default/smile.gif)
flywheel bolts and the locking plate (and felt washer) should be replaced, it's cheap insurance..... hardest part will be holding up the rear of the engine, but it's do-able.... |
Allan |
May 30 2006, 06:11 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
You can replace the rear main seal with the motor in the car. You have to have a way to support it and remove the tranny.
The bolts need to be replaced as well as the washer. It's also a great opportunity to replace the pilot bearing, clutch fork bushings and felt washer. |
So.Cal.914 |
May 30 2006, 06:23 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
Just bring the trans down so it has clearance to be removed. place jackstand
with a block of wood on top under engine, make sure it is stable. Remove trans from car, remove flywheel and the rear seal. I use a hook tool, a small piece of wood and a pair of visegrips, useing the piece of wood and the grips as a leaver. Install new seal and reassemble. Have fun.. (IMG:style_emoticons/default/smoke.gif) |
pfan12000 |
May 30 2006, 10:02 PM
thanks guys,
I have access to a lift and a lift table to hold up the engine and tranny. I have done a clutch job many times on a 914 and 911 but this time I'm looking for shortcuts since my spare time is less available with a 2.5y old daughter. This engine is in need of rebuilding and for now I just want to stop the leak which makes for embarassingly smoky stops at lights. |
Cap'n Krusty |
May 30 2006, 11:02 PM
thanks guys, I have access to a lift and a lift table to hold up the engine and tranny. I have done a clutch job many times on a 914 and 911 but this time I'm looking for shortcuts since my spare time is less available with a 2.5y old daughter. This engine is in need of rebuilding and for now I just want to stop the leak which makes for embarassingly smoky stops at lights. I can't believe you've done "many" clutch jobs on 914s and never just pulled the tranny. There's a well known Porsche guru who does them with the tranny hanging from the axles, still in the car. I thought EVERYBODY did clutch jobs with just the tranny out. BTW, replace the f/w o-ring, the washer, and the felt ring (if it's hard). Forget the bolts. 80 ft lbs is about half the torque those bolts can take, and they'll never break if torqued properly. Oil the seal on both the inner and outer surfaces, and push it in. Make sure it's seated evenly all the way around. BTW, when you get it down to an hour, call me. I'll have a job for you ............... Have fun. The Cap'n |
pfan12000 |
May 31 2006, 11:32 AM
Thanks Captain,
I'll call you when I can do it in less than 1 h. (IMG:style_emoticons/default/drunk.gif) |
jr91472 |
May 31 2006, 12:42 PM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
Follow the Cap'n advice to the letter. Then do a search on rear main seals for other tips. These buggers love to leak if you don't put them in correctly...btdt
MartyYeoman |
May 31 2006, 01:26 PM
Senior Member Group: Members Posts: 1,520 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Be sure to check the sealing surface on the flywheel. If it isn't perfect (no pits, scratches, grooves etc) install a sleeve. It costs a lot less than a new flywheel and your new seal will appreciate it.
The transmission isn't all that heavy. When you are ready to reinstall it can be manhandled fairly easily. Take your time. |
zymurgist |
May 31 2006, 03:04 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Be sure to check the sealing surface on the flywheel. If it isn't perfect (no pits, scratches, grooves etc) install a sleeve. It costs a lot less than a new flywheel and your new seal will appreciate it. Where are you finding sleeves? Granted, I don't know all the VW guys in my area, but none of them seemed to have any idea where to find a sleeve to fit one of these flywheels. |
Lo-Fi Version | Time is now: 8th June 2024 - 06:08 AM |
