Frt trunk release cable |
914werke |
May 30 2006, 08:07 PM
"I got blisters on me fingers" Group: Members Posts: 10,119 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
if youve ever noticed this cable & its plastic sheath run a torturious path to the latch. (IMG:style_emoticons/default/sad.gif)
Its restrained by 3 or 4 metal tabs to the tub (what do you call those?) 1st Q: did those have the blk plastic covers on them? 2ndQ: As the cable passes behind the headlight bucket it routes down and back up thru a smal hole in the front trunk support steel (73-74). Did that hole have a rubber Gromet OE? |
Porsche Rescue |
May 30 2006, 09:07 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
Rich, you'll probably get a direct answer here, but if not ask Craig to look at his (my old) 33K mile phoenix red '74. It should have the answers re: rear trunk rod retainer and front cable questions.
Pat Garvey |
May 31 2006, 07:25 AM
Do I or don't I...........? Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States |
if youve ever noticed this cable & its plastic sheath run a torturious path to the latch. (IMG:style_emoticons/default/sad.gif) Its restrained by 3 or 4 metal tabs to the tub (what do you call those?) 1st Q: did those have the blk plastic covers on them? 2ndQ: As the cable passes behind the headlight bucket it routes down and back up thru a smal hole in the front trunck support steel (73-74). Did that hole have a rubber Gromet OE? Rich, I'll answer for a '72. No plastic tab covers - seems these were mostly used to cover tabs that hold wiring harness in place (smart idea!). No grommet in support member (not so sure THAT was a good idea, though I don't see any rub marks after 34 years). I'd be surprised if they changed these themes for '73-74 models, but can't answer for them deifinitively. Pat G |
jim_hoyland |
Mar 19 2018, 04:55 AM
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
What is the correct length of the front trunk cable ? Also, the ferrules have been made in different lengths
Currently, I have a replacement cable that is short; to reach the latch the cable takes a shortcut across the corner of the trunk. Here’s a couple of pics of ferrules, but want to get the overal length so my cable will not cut the right front corner. Attached image(s) |
Mikey914 |
Mar 20 2018, 09:47 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
My 72 that is pretty much stock has no grommet.
Also only the wire hold downs have the blach plastic covers Attached thumbnail(s) |
Lo-Fi Version | Time is now: 1st June 2024 - 11:51 PM |
