timing mark on a 1.8, so every where i look |
messix |
Jun 1 2006, 09:40 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
there is no indent, no scribe, no cast in marks any where!
wtf!!!!!!!!! so i get it to tdc on the dizzy,[ i think] and push the car i little and i find about an inch of black on the impeller with a blade centered on it. did i find my 7.5% time mark? so anyway i calked the blade and timed it on that. seems to run ok. fire away! |
Mueller |
Jun 1 2006, 10:08 PM
there should be a mark on the flywheel as well for referance....
go check out the tech article @ Pelican on timing...they show a template that'll give you a good idea where to look and how to mark it.... |
messix |
Jun 1 2006, 10:10 PM
messix |
Jun 1 2006, 10:15 PM
ok so i read the timing for carbs tech and it mentions that the marks are tucked up on the back of the impeller? now does that make sense?
Mueller |
Jun 1 2006, 10:37 PM
there should be a mark on the flywheel as well for referance.... go check out the tech article @ Pelican on timing...they show a template that'll give you a good idea where to look and how to mark it.... yeah i did. not much help. no mark at tdc or 7.5%. that is why you print out the template, to make the TDC and 7.5° mark (IMG:http://www.pelicanparts.com/techarticles/914_timing/914_timing_pic6_big.JPG) |
messix |
Jun 1 2006, 10:50 PM
no worrries just got done. used a mirror and adjustable timing light. i had it at about 20%.
had to readjust idle also. |
Porsche Rescue |
Jun 2 2006, 07:35 AM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
This might help for next time.
Attached image(s) |
Lo-Fi Version | Time is now: 8th June 2024 - 02:25 AM |
