914 oil temp wiring |
galto |
Jun 3 2006, 02:25 AM
Newbie Group: Members Posts: 1 Joined: 3-June 06 Member No.: 6,138 |
Where in the world does that little green wire go?
I did a rebuild and I was 'sure' I would remember that, but I have failed, anyone help me, perfer w/ some pics! Thanks everyone. I would like to get my guages working right, seeing as they are there in that expensive center console. Thanks! |
scruz914 |
Jun 3 2006, 03:30 AM
Senior Member Group: Members Posts: 815 Joined: 26-February 04 From: Santa Cruz, CA Member No.: 1,724 |
I assume you want to know where it goes on the engine. The wire winds its way from inside the engine compartment down through a hole in the tin (passenger side), across the engine mounting bar to a thing called the taco plate (see photo). The connection on the taco plate is inside the hole and kind of hard to see. There should/might be a plastic covered push-on connector at the end of the wire that comes out of the hole in the tin. This end connects to the same color wire (grn/blk) coming out of the harnes,s which originates at the gauge. Do a search for "taco plate AND oil temp sender" for more information. Oh, and let me be the first to welcome you to the Club. -Jeff |
SirAndy |
Jun 3 2006, 09:53 AM
Resident German Group: Admin Posts: 41,676 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I did a rebuild and I was 'sure' I would remember that from the main harness plug, just under the battery tray, to the "taco" plate on the bottom of the motor, front drivers side ... and btw. the wire is green with a black stripe ... (IMG:style_emoticons/default/smile.gif) Andy |
wertygrog |
Jun 3 2006, 11:13 AM
wertygrog Group: Members Posts: 428 Joined: 12-November 05 From: Long Beach, CA Member No.: 5,114 Region Association: Southern California |
(IMG:style_emoticons/default/hijacked.gif)
My '74 came with the center console from the factory, but the temp gauge does not seem to register the oil temp correctly. The guage zeroes just fine when the car is turned on (flicks up a bit), but does not go up as the engine warms up.....could this be faulty wiring, or a bad temp sender? Could I apply a voltage to the sender wire to see if the guage is working correctly? If so are we talking somewhere between 0 and 1V? O BTW (IMG:style_emoticons/default/welcome.png) brent |
Lo-Fi Version | Time is now: 8th June 2024 - 12:21 AM |
