Power washing the engine?, Please give me a how to on oil removal. |
JPB |
Jun 3 2006, 07:27 AM
The Crimson Rocket smiles in your general direction. Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
I will have to get this beast cleaned under the engine since the beather tubes blew oil all over the engine for the past umpteen years. The last owner must have driven the hell out of it and I guess this could be a potential fire hassard. Do I heat up the engine, cover the alternator, use Gunk, thinners, power wash, clean it when its cold? I need experienced veterans to give me a fool proof approach to do this correctly. What say you!
(IMG:style_emoticons/default/blink.gif) Duhhma use hot wadder? |
Joe Bob |
Jun 3 2006, 07:33 AM
Unregistered |
There's been a few degreasing threads of late...might wanna search...but when I pulled my drive train for the trans rebuild, I used purple stuff from FLAPS, brake cleaner, a brush and water blaster......
It's A LOT easier when you have it on an engine stand. |
rhodyguy |
Jun 3 2006, 07:47 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,092 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
take $10 worth of quarters to your local spray-n-wash and get the bulk of it off. carry some WATER DISPLACEMENT 40 to spray in the dist cap if it won't start. wear your rain gear.
k |
Joe Bob |
Jun 3 2006, 08:00 AM
Unregistered |
Be careful about the spray and wash....they may not allow degreasing. Depends on how anal the local enviro weenies are.....
rhodyguy |
Jun 3 2006, 08:06 AM
at my local one you can clean engine compartments, 4x4s that have been out mudding, dirt bikes,...but NO PARTS CLEANING!! i've been busted before. i go at 6am.
k |
JPB |
Jun 3 2006, 10:51 AM
Ahhh, words of wisdom and well noted. I guess a jack would give my motives away I guess and a yellow rainsuit will be worn, good idea.
Mark Henry |
Jun 3 2006, 10:52 AM
Cover any openings with a plastic bag and also wrap up the dizzy. Don't go crazy around the oil fill cap, etc...
Do it cold. Start the car right away and drive it a good 15min. |
Aaron Cox |
Jun 3 2006, 10:55 AM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
i would also say do an oil change ASAP as water always makes it into the case
JPB |
Jun 3 2006, 11:07 AM
Yes, white frothy oil is not a good engine lubricator, good advice!
(IMG:style_emoticons/default/popcorn[1].gif) Kinda sounds like a day job from a spray job.. |
Lo-Fi Version | Time is now: 9th June 2024 - 09:55 AM |
