boxsterfan |
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California ![]() |
My friend and I were comparing our 914's this weekend (his is a driver and mine is on jacks in the garage). We noticed that both of our front hoods seem to sit above the fender line. So, we took a look at some 914 pics on the internet and saw that some 914's also had this feature.
So, what typically causes the front hood to ride above the fender line? |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
You mean the slight arch from front to back, usually worse on the passenger side?
Years of drooping over a gas nozzle, and being opened, and closed. M |
markb |
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California ![]() ![]() |
And the fix would be.....?
Don't tell me, replace the hood, right? |
redshift |
It's bent, you have to unbend it, which is actually bending it again. Let me give you a pointer: Don't UN-DO it by pushing up while it's open. (IMG:style_emoticons/default/smile.gif)
I think you need to remove it, and turn it upside down in a buck that is slightly less curved than the original profile, and then clamp the edges, and tighten them a little at a time, test fit, and repeat as needed. I think this is another one of the cases you would maybe use a little heat also, but not a hammer. (IMG:style_emoticons/default/wink.gif) M |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,234 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
or get someone to help ...
one presses down on the hood near the windshield, so you don't put pressure on the hinge mechanism while the other un-bends the hood. it's actually really easy, just go slow, otherwise you'll need a new paint-job. Andy |
Lo-Fi Version | Time is now: 1st July 2025 - 04:37 AM |
