arc914 |
Member ![]() ![]() Group: Members Posts: 139 Joined: 9-April 05 From: Sault Ste Marie,on,Canada Member No.: 3,905 ![]() |
hey hey
I bought a used centre console and i thought i read somewhere that all harnesses had the connectors pre-wired incase you wanted this option. well i wanted this option but on a quick review of the underside of my dash and the floor wiring i found nada. is this true or am i searchung for sometin that is not there? i have a 73 914-4 help a brotha out with your knowledge andrw in the Soo (IMG:style_emoticons/default/WTF.gif) |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,688 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
the extra wiring was added in '73, but i'm not sure if that is correct for all cars of that year.
if yours is an early '73, there's a good chance it doesn't have the wires ... look for a bundle of connectors on top of the center tunnel, under the carpet, right next to the shifter, pass. side ... (IMG:style_emoticons/default/smile.gif) Andy |
tracks914 |
Canadian Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None ![]() ![]() |
I agree with Andy, My early 73 doesn't have the wiring and neither did my 72 but it was easy to install. The hardest part was getting the temp sender and taco plate for the underside of the engine.
For the rest you just need a constant "hot" wire for the clock, an ignition "hot" wire for the voltmeter and tap off that same hot wire to go through the temp guage and continue on back to the temp sender unit under the engine. The brown wires all go to ground and the last wires are for the lights. They can be hooked to the dash lights. Not a big deal at all. |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Did your center console come with the wiring harness on it?
arc914 |
ok so i need to look by the shifter around by the pass side right.if it is not there then mine is to early a 73.my vin is 4732900560 is that an early run? my door jamb sticker was burned off when trying to remove it for paint.
do you know where i can get another made with the correct info? andrew in the Soo |
arc914 |
SLITS |
Cool, you're 80% home. In defference to Sur Ahandie, the flat plastic connectors are between the shift lever and the heater lever. If they are there, the wire colors will match the harness on your center(e) console.
If the connectors (look somewhat like headlight connectors) are not there, you will have to wire in the hot leads and grounds. |
wilchek |
Senior Member ![]() ![]() ![]() Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 ![]() |
check this out it is all u need to know http://www.pelicanparts.com/techarticles/9...ter_console.htm
. You will also need differnt heat lever and armrest to make it complete |
Lo-Fi Version | Time is now: 16th June 2024 - 10:30 PM |
