Need to be schooled, Rear suspension options |
germaneighter |
Jun 21 2006, 03:30 PM
Member Group: Members Posts: 130 Joined: 9-August 05 From: Tulsa, OK Member No.: 4,563 |
I am confused as to what my options are for rear shocks. I am using Bilstein front struts from a 911SC with stock torsion bars up front. I have the original Boge with sagged springs on the rear. I like the ride height that the worn out springs give but need to renew both shocks and springs. Current use is a lot of street and a little DE but I do not mind a more track-type stiffness.
I like the adjustable Koni but thought it was no longer available. Can used ones be rebuilt? If so, by who? Are the adjustable perch locations on Bilsteins adequate for my intended use? Does anyone make a retrofit threaded perch adjuster for Bilsteins? Anyone have a spring recommendation? |
jhadler |
Jun 21 2006, 04:19 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Kindof a can-of-worms question there...
The first question is: What is the result you're looking for? And the use? The second question is: What is your budget? A good base setup would be to keep the front torsion bars, upgrade the front sway abr (to a 22mm or so), and go to something like 140# rear coil on an adjustable perch. Put Koni's at all four corners, and you'll be a happy camper. There are a host of different things you can do, the question is: what do you want the car to do? And what are you willing to give up? A stiffer car will handle transitions better and be more responsive, but the street ride will suffer. -Josh2 |
Andyrew |
Jun 21 2006, 05:38 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
For 40 bucks from Coleman Racing, you have adjustable perches.
For another 100 from coleman you have new springs in exactly the lb rating you want. Shocks are the killer here... Koni's are still avalible, many places have them. (if you can. get yellow) And they can be rebuilt by koni themselves. bout 100 a piece IIRC. What about your front sway bar?? 4 cylander car... Read Josh's post. Andrew |
campbellcj |
Jun 21 2006, 11:42 PM
I can't Re Member Group: Members Posts: 4,549 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Bilstein shocks are great too and can be fitted with the Coleman collars and coil-over springs. There are lots of previous threads with details and pics about this. Definitely make sure your spring and shock rates 'match' the front end of the car or it'll be spin-city.
Andyrew |
Jun 21 2006, 11:49 PM
Or understeer city..... even worse for autox.
Lo-Fi Version | Time is now: 9th June 2024 - 01:38 PM |
