konis worth rebuilding?, old school |
grasshopper |
Jun 28 2006, 10:16 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
I got a pair of old konis for cheap, but they need rebuilding. I am assuming that these konis were from the 70's or 80's?? as they are not adjustable..or at least I dont know how to. But is it even worth it to rebuild these or should I just junk them??
Attached image(s) |
GeorgeRud |
Jun 28 2006, 10:27 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
They used to rebuild them (in the 70s), but I don't know what Koni's program is now. Probably time to give them a call.
Midtowner |
Jun 28 2006, 11:35 PM
Ooooo! Group: Members Posts: 652 Joined: 21-December 04 From: Sunnyvale, CA Member No.: 3,316 Region Association: None |
Timely thread. I have the same shocks on my ride and was thinking of the same thing as one option. (IMG:style_emoticons/default/popcorn[1].gif)
Andyrew |
Jun 28 2006, 11:43 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Contact Jason at Paragon... He is The Koni guy I believe....
Joe Ricard |
Jun 29 2006, 06:48 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
I would guess that a new set of Koni Sports would do you better in the long run.
RON S. |
Jun 29 2006, 07:18 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
I had these Koni's rebuilt by TrueChoice Motorsports up in Ohio about 6months ago.
Their standard rate I believe is 150-175.00 per shock. They are a authorized Koni rebuilder,and ALL Koni shocks are rebuildable. Question is,how much do you wanna put in them. Ron Attached thumbnail(s) |
Aaron Cox |
Jun 29 2006, 07:22 AM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
rons shocks were rare and i think a few way adjustable....
cheaper to buy NEW external adjustable konis.... nice paper weights there son (IMG:style_emoticons/default/smile.gif) |
maf914 |
Jun 29 2006, 07:28 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
The old Koni reds were adjustable, but only out of the car. I don't have the instructions available, but it involves pressing the push rod completely into the shock body to engage the adjustment mechanism. Now I'm guessing, but you turn the push rod (clockwise?) in one direction to zero the adjustment and get the softest setting, then turn it in the opposite direction (counter-clockwise?) to increase the resistance or firmness. Someone probably knows the proper procedure. (IMG:style_emoticons/default/idea.gif)
Eric_Shea |
Jun 29 2006, 07:34 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/agree.gif) Push the rod down until it engages and turn. Should say on the side of the shock.
Talk to Gordon at: Koni North America 1961 International Way Hebron, KY 41048 859-586-4100 x343 I agree with Aaron... might just be cheaper to get a set of new ones. I think the rebuild cost is $140 each and an extra $30 for a new rod with the adjustment knob on the top. |
Mike T |
Jun 29 2006, 07:35 AM
can't 'member Group: Members Posts: 378 Joined: 16-January 03 From: Brackney, PA Member No.: 161 |
I had these Koni's rebuilt by TrueChoice Motorsports up in Ohio about 6months ago. Their standard rate I believe is 150-175.00 per shock. They are a authorized Koni rebuilder,and ALL Koni shocks are rebuildable. Question is,how much do you wanna put in them. Ron Ron S. What Koni's are those? I noticed the sping perch mounts much lower than the Koni Reds I have on my 914. Mike T |
elwood-914 |
Jun 29 2006, 07:43 AM
elwood-914 Group: Members Posts: 387 Joined: 29-December 02 From: Plymouth CA Member No.: 38 |
RON S. |
Jun 29 2006, 09:08 AM
[quote name='Mike T' date='Jun 29 2006, 05:35 AM' post='715430']
[quote name='RON S.' post='715419' date='Jun 29 2006, 05:18 AM'] I had these Koni's rebuilt by TrueChoice Motorsports up in Ohio about 6months ago. Their standard rate I believe is 150-175.00 per shock. They are a authorized Koni rebuilder,and ALL Koni shocks are rebuildable. Question is,how much do you wanna put in them. Ron [/quote] Ron S. What Koni's are those? I noticed the sping perch mounts much lower than the Koni Reds I have on my 914. Mike T [/quote] Mike,those are a pair of early Dbl Adjustable(compression & rebound) Koni's for 914's.They are stamped 8/73 on each,so they are 30+years old.I found them at Hershey last year and got'em for $200.00 (IMG:style_emoticons/default/biggrin.gif) I could'nt pass em up. [quote name='elwood-914' date='Jun 29 2006, 05:43 AM' post='715435'] [/quote] Why is the rubber stop turned around it each shock?? [/quote] That is just the way they came out of the box from TrueChoice.They've been assemble & installled. Ron |
Lo-Fi Version | Time is now: 11th June 2024 - 10:57 AM |
