| retrotech |
Jul 1 2006, 09:51 PM
retrotech ![]() ![]() Group: Members Posts: 470 Joined: 2-November 03 From: Mosier, Oregon Member No.: 1,302 |
I went for a fairly aggressive, twisty drive last evening. I did some hard braking from over 100 mph. On the last stop, I felt something different in front, right wheel. I figured it was starting to lock up a bit. Everything felt the same. Today I go for a drive on the highway, and notice my steering wheel is now 2 clicks to the right, when car is tracking straight ahead. When steering wheel is straight, I'm changing lanes to the left.
What could have happened? I seems to drive fine, doesn't pull, but steering wheel angle has definately changed. Any ideas? |
| drive-ability |
Jul 2 2006, 12:00 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
I went for a fairly aggressive, twisty drive last evening. I did some hard braking from over 100 mph. On the last stop, I felt something different in front, right wheel. I figured it was starting to lock up a bit. Everything felt the same. Today I go for a drive on the highway, and notice my steering wheel is now 2 clicks to the right, when car is tracking straight ahead. When steering wheel is straight, I'm changing lanes to the left. What could have happened? I seems to drive fine, doesn't pull, but steering wheel angle has definately changed. Any ideas? I can't say whats wrong but the pressure applied to the front end while braking from high speed can cause things to be highly stressed. I for one would be taking a look at the front end for sure right away. safety first (IMG:style_emoticons/default/flag.gif) |
| -JR- |
Jul 2 2006, 12:18 AM
Life goes faster at 150MPH ![]() ![]() Group: Members Posts: 276 Joined: 12-May 04 From: Victoria BC Canada Member No.: 2,055 |
I went for a fairly aggressive, twisty drive last evening. I did some hard braking from over 100 mph. On the last stop, I felt something different in front, right wheel. I figured it was starting to lock up a bit. Everything felt the same. Today I go for a drive on the highway, and notice my steering wheel is now 2 clicks to the right, when car is tracking straight ahead. When steering wheel is straight, I'm changing lanes to the left. What could have happened? I seems to drive fine, doesn't pull, but steering wheel angle has definately changed. Any ideas? I'd guess I frozen caliper.... But I'm "guessing". Check the wheel temps left and right after a road test. It's a quick check at least. -JR- |
| SirAndy |
Jul 2 2006, 12:54 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,562 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
| So.Cal.914 |
Jul 2 2006, 01:32 AM
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
The preasures associated with breaking the sound barrier can be tremendous
and damage can occure, or it could be that cat you ran over. But what Andy said makes more sense. |
| JPB |
Jul 2 2006, 05:02 AM
The Crimson Rocket smiles in your general direction. ![]() ![]() ![]() ![]() Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
Could be Crazy glue on your steering wheel and its coming LOOSE! These cars had like multiple owners so nothing is impossible!
(IMG:style_emoticons/default/WTF.gif) Why are all my wires all the same color? |
| retrotech |
Jul 2 2006, 09:09 AM
Not a frozen caliper, it drivews & brakes fine. How could high speed braking cause a tie rod end to unscrew?
| Katmanken |
Jul 2 2006, 10:17 AM
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Iffin it was me,
I 'd just jack the sucker up in the air and do a little look see.... Aint that many parts associated with one front wheel. And, while you are under there, check the rear trailing arms. Having a rear mounting point break might make the car track different. Or, the bolts holding the steering rack are loose and shifted... Or some rust let go.... Or... Ken |
| Joe Bob |
Jul 2 2006, 10:36 AM
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Probably an alignment issue. Take it and have it up on the rack and check specs.
| So.Cal.914 |
Jul 2 2006, 12:49 PM
Hard driving and hard braking can cause vibration and stresses that can loosen
just about anything, it's not a spring chicken anymore. Alot of racers will check every bolt before the next race and it is not uncommon for them to find something to tighten. |
| retrotech |
Jul 2 2006, 01:33 PM
Hard driving and hard braking can cause vibration and stresses that can loosen just about anything, it's not a spring chicken anymore. Alot of racers will check every bolt before the next race and it is not uncommon for them to find something to tighten. I have a DE day coming up, so I shoould be glad this happened now. With 13.7" GTP brakes, and 235/17 Toyo RA1 tires, I have serious deceleration. |
Lo-Fi Version | Time is now: 23rd November 2026 - 01:39 AM |
