Installed JWest Fog Light Flash module, quick, easy, and cool! |
BigDBass |
Jul 4 2006, 11:37 AM
Dumb Question Champion Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest |
I just installed the JWest fog light flash module. It took me about a half hour and the provided instructions were clear and effective. I debated using Demick's
foglight rewiring instructions but didn't want to cut my harness at all. The best feature of this modification is that you can sit in the car in your garage and flash the fogs on and off and pretend you are telling Steve McQueen to get out of your way at LeMans! (IMG:style_emoticons/default/biggrin.gif) |
dinomium |
Jul 4 2006, 09:22 PM
Git on a chair son, all the good stuff is goin over yer head! Group: Benefactors Posts: 2,777 Joined: 2-January 03 From: Bremerton, WA Member No.: 74 Region Association: Pacific Northwest |
I just installed the JWest fog light flash module. It took me about a half hour and the provided instructions were clear and effective. I debated using Demick's foglight rewiring instructions but didn't want to cut my harness at all. The best feature of this modification is that you can sit in the car in your garage and flash the fogs on and off and pretend you are telling Steve McQueen to get out of your way at LeMans! (IMG:style_emoticons/default/biggrin.gif) Right on, Dan! That is a really well put together item, too bad my stalk wont toggle the hibeams on my car at all! (IMG:style_emoticons/default/confused24.gif) PO wiring!! But a good product and easily worth the 26 bux! |
double-a |
Jul 4 2006, 10:00 PM
Senior Member Group: Members Posts: 987 Joined: 15-September 03 From: vancouver, wa, usa Member No.: 1,162 Region Association: Pacific Northwest |
I just installed the JWest fog light flash module. It took me about a half hour and the provided instructions were clear and effective. I debated using Demick's foglight rewiring instructions but didn't want to cut my harness at all. The best feature of this modification is that you can sit in the car in your garage and flash the fogs on and off and pretend you are telling Steve McQueen to get out of your way at LeMans! (IMG:style_emoticons/default/biggrin.gif) Right on, Dan! That is a really well put together item, too bad my stalk wont toggle the hibeams on my car at all! (IMG:style_emoticons/default/confused24.gif) PO wiring!! But a good product and easily worth the 26 bux! agree, very good product. and there will be one on the auction block at the wcc charity auction! along with a rennshift of course >:) ~a |
grasshopper |
Jul 4 2006, 10:12 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
hell yeah! I installed mine the other day too. Took about ten minutes and now I have fogs that I can actually use! Great product!
blitZ |
Jul 5 2006, 05:23 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I lost my high beams after installing mine? Anyone have the same problem?
dinomium |
Jul 5 2006, 10:29 AM
I have no hibeams after, but I think it was PO wiring that did me in. I tried puting things back the way I found them, but it was too late... Damage done.
what year is your car? Mine is a 1970. |
grasshopper |
Jul 5 2006, 11:02 AM
..??? I had no Highbeams after too... I installed a new headlight relay and it worked fine..
BigDBass |
Jul 5 2006, 11:50 AM
Hmm, I haven't tried the highbeams. I literally never use them anyway. I'll see if they work when I get home.
auggie91420 |
Jul 5 2006, 07:08 PM
Newbie Group: Members Posts: 41 Joined: 6-July 05 From: Altadena, CA Member No.: 4,380 |
carreraguy |
Jul 5 2006, 08:55 PM
It's not your dad's 914! Group: Members Posts: 1,197 Joined: 17-October 03 From: San Jose, CA Member No.: 1,256 Region Association: Northern California |
Hmm, I haven't tried the highbeams. I literally never use them anyway. I'll see if they work when I get home. I wonder if Craig's "Pilot" foglight mod would make up the difference if you didn't have a high beam after the mod? I've ordered both the Flash Module and the Pilots. |
BigDBass |
Jul 5 2006, 09:43 PM
Just tested, and my highbeams work fine.
Tossing in easy stuff like this with immediate, visible results in between the higher learning curve stuff has helped build my confidence and not burn out. Next up will be Pilots from Camp and/or the "Hella Vision Plus" H4 conversion from Performance Products. And it will be a loooong time before my monster catches up to CMXIV! (IMG:style_emoticons/default/biggrin.gif) |
dinomium |
Jul 5 2006, 11:47 PM
I swapped out realys, now I have hi beams only
Kookey I guess I should buy a nu one! fog lites work... (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 12:53 AM |
