Gauge Cluster Wiring |
StratPlayer |
Oct 10 2003, 11:16 AM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
I'm about to tackle the gauge cluster wiring, it seems that there are some wires that are not in the correct place etc.. I was wondering if there were any diagrams of the gauge cluster wiring or any pictures of a later model teener with the correct wiring for the gauge cluster. I have a combo gauge that I'm going to install and want to go thru the wiring an make sure that it is all correct.
Attached image(s) |
StratPlayer |
Oct 10 2003, 11:17 AM
I have an extra one of these gauges if anyone is in need.
Attached image(s) |
Brad Roberts |
Oct 10 2003, 12:08 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
We need to scan the color'd wires diagram.
You might be better off asking what wire color does what. Like list off everything you see on the BBS and let us tell you where each wire should go. I can look at it and tell you.. but I cant tell you from memory. B |
Kerrys914 |
Oct 10 2003, 12:26 PM
Dear, the parts I just sold paid for that part ;) Group: Members Posts: 1,568 Joined: 26-December 02 From: Williamsburg, VA Member No.: 16 |
If someone can fax me a hand sketch of their corectly wired gauge cluster I will pretty it up of posting on the club site. (IMG:style_emoticons/default/smile.gif)
Or Three close up photo's e-mailed to me kerrys914@comcast.net Cheers (IMG:style_emoticons/default/beer.gif) Kerry H 804-217-8520 |
StratPlayer |
Oct 10 2003, 01:09 PM
Trying to post a sketch I made when I removed the gauges, but keep getting timed out on the upload of the sketch.
StratPlayer |
Oct 10 2003, 01:20 PM
xoxoxxo
Attached image(s) |
StratPlayer |
Oct 15 2003, 02:16 PM
(IMG:style_emoticons/default/confused24.gif) Maybe one of you can fill the rest of these out
Gauge Cluster Wiring (Combo Gauge) Brown Wire = Ground Black w/Blue Stripe = Instrument Illumination Red w/White Stripe = Swithched Power On Green w/Black Stripe = ?? Blue = ? Green = ?? (IMG:style_emoticons/default/confused24.gif) |
Dave_Darling |
Oct 15 2003, 04:50 PM
Green/black == oil temperature gauge signal
Blue == alternator light Green == fuel gauge signal Green/red == oil pressure light Black == low fuel light There may be others I'm forgetting.... --DD |
StratPlayer |
Oct 15 2003, 05:10 PM
(IMG:style_emoticons/default/beerchug.gif) Thank You Dave, deeply appreciated, (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 1st June 2024 - 11:03 AM |
