050 distributor, 9-230-081-050 |
jimkelly |
Jul 15 2006, 07:18 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
I juts acquired a 050 dist - pn in topic description.
I am installing a single progressive carb on my 1.8 to simplify things - primarily so I can get moving on my second 914 which wll get a subaru engine - but I can't start that project until I can drive my main 914 out of my garage space to work on my conversion project. Anyway - will an 050 distributor be any better than the stock 1.8 distributor? Jim |
Gint |
Jul 15 2006, 09:42 PM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Better? I dunno, but I wouldn't think the advance curve would be as good. But I don't have the specs to back that up. IMHO I would use the stock 1.8 unit.
eg914 |
Jul 15 2006, 11:24 PM
Member Group: Members Posts: 319 Joined: 17-June 04 From: Elk Grove, CA Member No.: 2,223 Region Association: None |
My car has the single progressive carb and a 1.8L distributor. Works as good as can be expected for the single carb (it is very sensitive to ambient temperatures). The vacuum advance is fine with the progressive.
jimkelly |
Jul 16 2006, 12:06 AM
thanks guys - similar views as I have received before - juts figured that the 009 and 050 without vaccum advance were made for a reason - either way - I will use stock 1.8 dist : )
alpha434 |
Jul 16 2006, 12:24 AM
My member number is no coincidence. Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
The stock 1.8 dizzy IS 050. Or that's what my car has stock.
jimkelly |
Jul 16 2006, 05:06 AM
I've heard that there is more than one version of the 050 - does yours have vaccum advance ??
But I only see one 050 on the pelican website ... http://www.pelicanparts.com/catalog/shopca..._pg3.htm#item14 Jim |
Joe Bob |
Jul 16 2006, 06:43 AM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
050s are no longer available....of the two, the stock 1.8 is better.....
050 is sought after by the 356 crowd. The 009 is mostly made in Brazil and was originally designed for the staitionary industrial motor. Not the best advance curve. |
Gint |
Jul 16 2006, 09:18 AM
The stock 1.8 dizzy IS 050. Or that's what my car has stock. No it's not. It has 050 in the part number, but it's not the same part nnumber. Look at the entire part number for a "050" and a stock 1.8 dizzy (the one with 050 in the part number) and you'll see that they're not the same part number. |
SLITS |
Jul 16 2006, 09:23 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
All Bosch dizzy numbers start with 0 (0 XXX XXX XXX) with the exception of "aftermarket Non-OEM" which will start with a 9. The 9 indicates it was never fitted to an OEM automobile application and therefore is an "aftermarket" item.
Lo-Fi Version | Time is now: 1st June 2024 - 07:39 AM |
