snapped off exhaust stud, ok to heat it? |
stephen7 |
Jul 19 2006, 09:43 PM
Member Group: Members Posts: 69 Joined: 4-March 06 From: seattle wa Member No.: 5,663 |
Hey guys
I tried to use an easy-out but this broken heat exchanger stud is stuck. Since the head is aluminum and the stud is (?) some hardened metal - will this work? I took the fuel line off and ran the engine until it stopped so hopefully I won't blow myself up in the process (IMG:style_emoticons/default/huh.gif) . what do you think? thanks |
bd1308 |
Jul 19 2006, 09:58 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
ok
heres what you do 1)grab welder 2)grab nut that fits and/or screws onto stud 3)weld nut to stud 4)get LONG and STRONG wrench 5)Heat stud area up at head, turn wrench after a few times and possible snapped off stud, you should get it out b |
Trekkor |
Jul 19 2006, 10:39 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
stephen7 |
Jul 20 2006, 10:46 PM
I snapped off the easy out today after using the torch method. Next is the welding. wish me luck.
McMark |
Jul 21 2006, 02:23 AM
Eeek, broken easy outs are no fun. If nothing else works, take it a machine shop that can use an EDM to get it out. When you're welding, don't arc to the aluminum.
Lo-Fi Version | Time is now: 9th June 2024 - 09:41 AM |
