| ottox914 |
Jul 28 2006, 11:14 AM
The glory that once was. ![]() ![]() ![]() Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
Took the day off work, getting alot done (finally) on the SDS install. The WMS wideband will end up on the dash, and has some fairly large cables/connectors to run back to the wideband sensor and connections to the SDS ecu. I was going to run this all thru the driver side heater passage in the rocker box. While I expect there is no need for ELECTRICAL shielding in this area, how about PHYSICAL shielding. I'd hate to have a wire rub raw in the rocker box area and short out the wideband.
So, how much protection will the wires running thru this area need? And, when I'm done for the day I'll take some progress photos and post to my SDS thread. |
| Eric_Shea |
Jul 28 2006, 11:20 AM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE whats inside the heater passage in the rocker box? Rust (IMG:style_emoticons/default/wink.gif) Actually there's a heater tube in there. Someone should have pics. Probably a decent pic in my -6 restoration thread search "fixing the six". It might give you an idea where the cable could be run. Use rubber grommets on the holes the cable goes through... fairly common. |
| nomore9one4 |
Jul 28 2006, 11:21 AM
Member of the Eastcoast Thread Killers Club ![]() ![]() ![]() ![]() Group: Members Posts: 2,666 Joined: 26-December 02 From: Pittsburgh,Pa.15237 Member No.: 14 Region Association: None |
Some say Jimmy Hoffa (IMG:style_emoticons/default/blink.gif)
| SirAndy |
Jul 28 2006, 12:00 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,539 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
some guys having fun with a heater tube ...
![]() and here's a closeup of the tubes ... ![]() and the long the tube came from ... ![]() (IMG:style_emoticons/default/smile.gif) Andy |
| Brad Roberts |
Jul 28 2006, 12:05 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Hey!
Blast from the past. Thanks Andy! Those where the days (of no pay..LOL) B |
| URY914 |
Jul 28 2006, 12:14 PM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 135,017 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Hence the term, "hung like a heater tube..."
| maf914 |
Jul 28 2006, 12:33 PM
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None
Hence the term, "hung like a heater tube..." (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) |
| ottox914 |
Jul 28 2006, 01:13 PM
So if I'm getting this right, there are no bits of sharp pointy metal in there, and running the wires thru this area should require no special care. I was planning to put the wires in some sort of sheathing before running them thru this area, just wasn't sure how bullit proof the sheathing needed to be. Or should I just run them thru?
And, for blocking off the ends of the heat passages, I found these at the local hardware store, which are rubber and pressure fit right over the ends. 2.99 each. Attached thumbnail(s)
| TravisNeff |
Jul 28 2006, 02:04 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region
Hmmm - SNACKS Attached image(s)
| tat2dphreak |
Jul 28 2006, 02:52 PM
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
I ran my push-button starter wire through it... (no heat anyway, so why not...)
| Brad Roberts |
Jul 28 2006, 04:10 PM
Go ahead and bundle your wires with a large piece of heat shrink. You will be fine.
I *wish* I was hung like a small bear.... oh wait? B |
| Dave_Darling |
Jul 28 2006, 04:29 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,364 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
...And, for blocking off the ends of the heat passages... IIRC, spray-can lids work also. And they come in lots of colors, so you can coordinate with the rest of the car! (IMG:style_emoticons/default/lol2.gif) --DD |
| ottox914 |
Jul 28 2006, 08:24 PM
I was doing the spray can lid thing before, but wanted something a little better for running the wires. I thought with the heat in the area, wires going thru the cap, well, I just was looking for something better, and for 2.99 a piece, I got 4, 2 for in the car, 2 for in the engine room. Call me a big spender...
| orange914 |
Jul 28 2006, 09:14 PM
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
[quote name='Eric_Shea' date='Jul 28 2006, 10:20 AM' post='739890']
[quote]whats inside the heater passage in the rocker box?[/quote] Rust (IMG:style_emoticons/default/wink.gif) seems a few of us have peeked in here (IMG:style_emoticons/default/sawzall-smiley.gif) Attached thumbnail(s)
| mihai914 |
Jul 28 2006, 10:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None
I hope these are helpful to you.
| ottox914 |
Jul 28 2006, 10:30 PM
Those are some amazing photos! I'll be running my wires thru there for the wideband O2 system, and expect I'll just find some rubber hose or something of the correct I.D. to use as a sort of a flexable conduit, then attach the conduit to the rubber end caps I found. I'll add some photos to the SDS thread tomorrow night when I'm done.
| Eric_Shea |
Jul 29 2006, 09:40 AM
Yeah... if you're capping it of and there's no heat simply run it through the tube. It comes out in the right spot.
| ottox914 |
Jul 29 2006, 07:36 PM
Got the WMS wideband installed, see my SDS install thread for photos.
| Dave-O |
Jul 29 2006, 08:12 PM
Is winter done yet? ![]() ![]() ![]() Group: Members Posts: 511 Joined: 26-August 03 From: Minneapols, MN Member No.: 1,082 |
Lo-Fi Version | Time is now: 18th October 2026 - 08:31 AM |
