Anyone use the Renegade steering wheel extension hub?, Bolt holes are larger and my recessed MOMO wheel doesn't fit... |
neo914-6 |
Aug 11 2006, 08:56 PM
neo life Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
Just curious if MOMO changed their screw size. I have a new MOMO and it has the same screw size as the old Porsche Design MOMO steering wheel. The PD, however has a recessed mount that's smaller than the extension which doesn't affect the flat faced new MOMO wheel.
To use it with this wheel, I'd need to have it turned down to the ID of the PD wheel and then drill larger holes and countersinks for the larger screws... Attached thumbnail(s) |
Aaron Cox |
Aug 11 2006, 09:35 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
have mike turn it down (IMG:style_emoticons/default/smile.gif)
neo914-6 |
Aug 11 2006, 11:34 PM
yeah after he finishes my shifter extension... (IMG:style_emoticons/default/laugh.gif)
The issue I have is the MOMO wheels have to be permanently modified for the larger screws and I'd have to drill and tap the shorter adapter if I wanted to use it... |
Chris Pincetich |
Aug 12 2006, 12:15 AM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
(IMG:style_emoticons/default/idea.gif) That looks like it would fit my old Dyno wheel, it uses some pretty big screws with a similar (same?) pattern as MOMO. I'm sure you'll figure something out...I'm surprised you're not trying a newer Porsche or Audi wheel with buttons on it.
Good luck! (IMG:style_emoticons/default/beerchug.gif) |
neo914-6 |
Aug 12 2006, 01:01 AM
(IMG:style_emoticons/default/idea.gif) That looks like it would fit my old Dyno wheel, it uses some pretty big screws with a similar (same?) pattern as MOMO. I'm sure you'll figure something out...I'm surprised you're not trying a newer Porsche or Audi wheel with buttons on it. Good luck! (IMG:style_emoticons/default/beerchug.gif) Hey Chris! Yep there are two patterns, one fits MOMO. Most modern wheels have large centers for airbags but I really like the Porsche Design wheel, it's simple and unique. If I ever adapt the Audi steering column I may have to use an Audi wheel, just no time to do everything... Thanks (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 28th May 2024 - 11:54 PM |
