Dizzy Disassembly, Pin 4 Driver Claw |
Gary# |
Aug 15 2006, 11:52 PM
Member Group: Members Posts: 217 Joined: 15-May 05 From: Buena Park, Ca. Member No.: 4,078 |
The 914 Manual sayz;
"Knock out pin 4 driver claw with a drift". Ahhhh - OK (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) Huummm (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) Huummm (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) This SUKZ - & the rebuild/shim kit I got to reset axial play doesn't include a replacement pin. I don't want 2 fuch this pin up with my (IMG:style_emoticons/default/smash.gif) Should I spark up the torch & give it another go - or go to HF & buy a small press? whatayathink??? Thx, Gary Attached image(s) |
McMark |
Aug 16 2006, 01:10 AM
Well known to be a PITA to get out. I gave up the ONLY time I tried. Hopefully someone has had better luck, because I'm curious to see the rest of your rebuild. (IMG:style_emoticons/default/wink.gif)
Bleyseng |
Aug 16 2006, 07:59 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
just use a long straight punch to knock it out. Once you start it, they come out..
(IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/thumb3d.gif) |
toon1 |
Aug 16 2006, 08:06 AM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
just use a long straight punch to knock it out. Once you start it, they come out.. (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/thumb3d.gif) (IMG:style_emoticons/default/agree.gif) I made a mark on the bottom to I.D. the orientation so it doesn't go back together 180 out. |
Gary# |
Aug 16 2006, 08:43 AM
just use a long straight punch to knock it out. Once you start it, they come out.. (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/thumb3d.gif) (IMG:style_emoticons/default/agree.gif) I made a mark on the bottom to I.D. the orientation so it doesn't go back together 180 out. ----- Thx - I made a mark too & I'm takin' pics just 2 be safe. The part I'm having trouble with is the "Once you start it, they come out.." part. I small press would make this a non-issue. |
Marlow |
Aug 16 2006, 09:14 AM
Member Group: Members Posts: 311 Joined: 14-August 03 From: Manassas, VA Member No.: 1,027 |
I rebuilt my dizzy and had a lot of trouble getting that pin out. Had to do it twice as I reassemble it 180 degrees off. The bottom part is not very hard metal, I managed to put a few dings in mine and had to file them smooth.
I would recommend against heat, there are some fiber washers in there. |
Gary# |
Aug 16 2006, 11:52 AM
I'm taking this puppy home with me tonite & I'm gonna (IMG:style_emoticons/default/owned.gif) that pin!!! When I was smacking the drift with my BFH (IMG:style_emoticons/default/smash.gif) last nite & the pin didn't move - I knew I needed 2 STOP B4 it was too late!!! (IMG:style_emoticons/default/w00t.gif) Nuttin' like having the right tool 4 the job - (IMG:style_emoticons/default/beerchug.gif) Attached image(s) |
TravisNeff |
Aug 16 2006, 12:00 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
That pin is a bitch to get out, as it the dizzy tries to spin. I ended up using a vise, screw and a socket. You will also need to get out the c-clip at the top of the dizzy shaft, take out the felt and you can see the clip holding the upper to lower dizzy shaft together.
Gary# |
Aug 17 2006, 01:47 AM
I stopped and bought a 10" arbor press on the way home from werk. And it was STILL a PITA biotch to get the pin to move - but it finally broke free (IMG:style_emoticons/default/beerchug.gif) Schweet!!! (IMG:style_emoticons/default/clap56.gif) Attached image(s) |
Dr Evil |
Aug 17 2006, 09:57 AM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Where did you get a new bushing kit? Do you know if they had them for 911 dizzies? That would fix my latest problem......hijack over (IMG:style_emoticons/default/biggrin.gif)
Gary# |
Aug 17 2006, 10:45 AM
Where did you get a new bushing kit? Do you know if they had them for 911 dizzies? That would fix my latest problem......hijack over (IMG:style_emoticons/default/biggrin.gif) ----- Evil-One - Cap'n Krusty recommended stoddard.com for the bushing kit - Cap,n quote: "washers and shims for the shaft were available from stoddard, but you have to order a kit for a 356 cast iron distributor. The shaft bushings are available from some Volvo aftermarket sources." Thx again Cap'n!!! (IMG:style_emoticons/default/smiley_notworthy.gif) (IMG:style_emoticons/default/smiley_notworthy.gif) (IMG:style_emoticons/default/smiley_notworthy.gif) ----- I don't (IMG:style_emoticons/default/stromberg.gif) 'bout 911 dizziez - maybe the Cap'n will chime in...?? |
zen motorcycle |
Sep 27 2006, 09:43 AM
almost not a newbie ( way less than a newbie) Group: Members Posts: 259 Joined: 21-May 06 From: Dallas Member No.: 6,038 Region Association: None |
Where did you get a new bushing kit? Do you know if they had them for 911 dizzies? That would fix my latest problem......hijack over (IMG:style_emoticons/default/biggrin.gif) ----- Evil-One - Cap'n Krusty recommended stoddard.com for the bushing kit - Cap,n quote: "washers and shims for the shaft were available from stoddard, but you have to order a kit for a 356 cast iron distributor. The shaft bushings are available from some Volvo aftermarket sources." That is for the 205 dizzy right??? And does anybody know the Volvo part number or name? |
pbanders |
Sep 27 2006, 11:04 AM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
That pin is a bitch to get out, as it the dizzy tries to spin. I ended up using a vise, screw and a socket. You will also need to get out the c-clip at the top of the dizzy shaft, take out the felt and you can see the clip holding the upper to lower dizzy shaft together. IIRC, Krusty told us that the best way to remove the c-clip was to hit the top of the shaft with a drift and it would pop off. Anyone ever actually do this? |
Lo-Fi Version | Time is now: 7th June 2024 - 07:07 AM |
