> carbon fiber hood/trunk supports, Pictures
Randal
post Aug 20 2006, 01:41 PM
I've bought the Seine System universal kit which has both the carbon fiber trunk and hood supports.
Anyone install these units? It sure isn't obvious where they can go and still function and look clean.
Pictures would be greatly appreciated.
Thanks.
neo914-6
post Aug 20 2006, 02:59 PM
neo life
Randal,
Looks like a nice solution, you're probably the first to try this kit on a 914. I was thinking of using an old carbon fly rod.
For neo914 I ended up with lower pressure CAMP914 gas shox. After I ordered Craig mentioned I may want to try 1 first, probably because f/g and CF hoods and lids have different weights...
Randal
post Aug 20 2006, 03:40 PM
QUOTE(neo914-6 @ Aug 20 2006, 01:59 PM) *
Randal,
(Front hood) There doesn't seem to be a mounting point on the inter fender that will work, given the curve of the fender, i.e., the rod can't bend around the fender curve when shut.
Maybe the ridge which sits in front of the tank would work (perpendicular to the fenders) and still have sufficient room for the rod to "be packed up," so to speak.
Same issue applies to the rear trunk.
I’ve got a CF hood and trunk as well.
I hope I'm not the first, but judging from the responses to this post, I might be.
Jeroen
post Aug 20 2006, 03:51 PM
Region Association: Europe
check Armando's site for pics of the original GT hood prop
it's a nice set up, that would be fairly easy to make
Randal
post Aug 20 2006, 04:18 PM
QUOTE(Jeroen @ Aug 20 2006, 02:51 PM) *
Thanks Jeroen.
I did a search on Armando, but couldn't find anything. Do you have a link?
Jeroen
post Aug 20 2006, 04:37 PM
Here's the link to Armando's site
http://www.pbase.com/9146gt
These pics give you an idea how it's done
I've seen other/better pics there, but these were the quickest I could find and should give you a good idea
(IMG:http://mishilo.image.pbase.com/u36/9146gt/large/23456221.HBGT2006.jpg)
(IMG:http://mishami.image.pbase.com/u34/9146gt/upload/22398214.HB9146GT003.jpg)
(IMG:http://k41.pbase.com/u36/9146gt/large/23456216.HBGT2001.jpg)
(IMG:http://k53.pbase.com/u34/9146gt/large/22398210.HB9146GT000bGagnonotherphoto.jpg)
Eric_Shea
post Aug 20 2006, 04:44 PM
PMB Performance
How about on the bulkhead in front of the tank? Not sure how long it is etc... sideways mount there??
Yaaa-Roon... no pics (IMG:style_emoticons/default/confused24.gif)
Jeroen
post Aug 20 2006, 05:14 PM
QUOTE(Eric_Shea @ Aug 21 2006, 12:44 AM) *
whaddayamean? I can see the pics just fine (IMG:style_emoticons/default/confused24.gif)
Eric_Shea
post Aug 20 2006, 05:23 PM
PMB Performance
This is what I see...
J P Stein
post Aug 20 2006, 05:27 PM
Irrelevant old fart
Randal.....you still have hinges????
F & R gotta be 6-8 lbs. (IMG:style_emoticons/default/biggrin.gif)
Jeroen
post Aug 20 2006, 05:34 PM
QUOTE(Eric_Shea @ Aug 21 2006, 01:23 AM) *
ok... that's weird...
do they work as links?
http://mishilo.image.pbase.com/u36/9146gt/...21.HBGT2006.jpg
http://mishami.image.pbase.com/u34/9146gt/...HB9146GT003.jpg
http://k53.pbase.com/u34/9146gt/large/2239...notherphoto.jpg
jonwatts
post Aug 20 2006, 05:36 PM
no rules, just wrong
nerp
Eric_Shea
post Aug 20 2006, 05:56 PM
PMB Performance
nada
Randal
post Aug 20 2006, 07:16 PM
QUOTE(J P Stein @ Aug 20 2006, 04:27 PM) *
HISTORY (IMG:style_emoticons/default/happy11.gif)
Randal
post Aug 20 2006, 07:18 PM
QUOTE(Jeroen @ Aug 20 2006, 04:34 PM) *
Anyone else get these to work?
Forbidden
You don't have permission to access /u36/9146gt/large/23456216.HBGT2001.jpg on this server.
Apache/2.0.46 (Red Hat) Server at k41.pbase.com Port 80
JPB
post Aug 20 2006, 07:24 PM
The Crimson Rocket smiles in your general direction.
Okay bro. Ya started something that I need to end. I have the same issue and am very happy to see some cool ideas. I think if ya go to Lowes and get an ALUMINIUM ROD, flatten it at one end with a hammer and drill a hole big enough for a small bolt this would solve your proble and mine.LOL At the end where it touches your hood, Lowes sells small end caps which should slid right over the strock rod. I use a cut broom handle and this alternative would be the trick part. Thanks again for the inspiration and good luck!
(IMG:style_emoticons/default/beer.gif)
Jeroen
post Aug 20 2006, 07:34 PM
ok, then this should work...
Randal
post Aug 20 2006, 07:39 PM
QUOTE(JPB @ Aug 20 2006, 06:24 PM) *
Good ideas, but these babies are nice. One is 33" the other 21." Guess the longer one is for the front.
neo914-6
post Aug 20 2006, 08:34 PM
neo life
Funny how you get attached to nice hardware and will someway make it work, I should know. (IMG:style_emoticons/default/biggrin.gif)
Another example, Chris Julian designed dual aluminum rods. You only see one up in this pic mounted ahead of the gas tank:
Randal
post Aug 21 2006, 09:51 AM
The perple from Seine wrote me this morning.
They don't have any pictures of 914 installation with the Universal support rods, so guess I'll just have to noodle it out; of course with help from our contributors to this board.
- Lo-Fi Version Time is now: 10th September 2026 - 09:58 AM
