Anyone using 16" 5 lug fuchs? |
kenschipper |
Sep 4 2006, 05:35 PM
Member Group: Members Posts: 186 Joined: 5-May 04 From: San Juan Bautista, CA Member No.: 2,025 Region Association: Northern California |
Is anyone using 16" five lug Fuchs under standard fenders. What tire size and rim width will usually fit. Photos?
Aaron Cox |
Sep 4 2006, 06:37 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
195's on 6"
smj |
Sep 4 2006, 06:53 PM
"Dude, Steve from Berkeley." Group: Members Posts: 591 Joined: 28-August 05 From: Berkeley, CA Member No.: 4,691 Region Association: Northern California |
I have 16" Fuchs taken off an '86 Carrera, allegedly 16x6 up front and 16x7 in back. I've got Yokohama AVS ES100's mounted, 205/55ZR16 flavored.
The rear fenders had been rolled a bit, and that wasn't enough to clear the 225s the PO was running there. I haven't had the car back from the shop a week yet, but I'm still seeing some rubbing when braking and turning on the switchbacks up in the Berkeley hills. So, seems we really did need to take the spacers down a bit in front... I haven't taken the wheels off to verify the sizes, but if the above is correct than the fronts have an offset/ET of 36mm, and the rears of 23mm. Here's a link that lists a lot of info on the factory wheels: http://members.rennlist.com/911pcars/WheelWts.html |
brownaar |
Sep 5 2006, 03:45 PM
Member Group: Members Posts: 263 Joined: 23-September 04 From: Gate City, VA Member No.: 2,813 Region Association: None |
Bridgestone RE71 205/55ZR16 on 16X6. I'm thinking you have to use an early Fuchs, deeper offset I believe. Mine don't rub the fender, but do rub a little on the inner fenderwell with a really sharp turn-in.
Britain Smith |
Sep 5 2006, 06:05 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
I am running 16" fuchs on my Turbo 912 project, I got a set of Falkin's in 205/40/16.
-Britain |
Allan |
Sep 5 2006, 06:09 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I was running 16 x 6 with 205/55's all around on my /4 with just the rear fenders rolled in. Fit really well.
I would be running them now exept I thought my "new" /6 had a 5 lug conversion until I sent the check... (IMG:style_emoticons/default/sad.gif) |
Aaron Cox |
Sep 5 2006, 06:27 PM
ouch allan
dgw |
Sep 5 2006, 06:54 PM
Dennis Winter Group: Members Posts: 553 Joined: 7-January 03 From: Santa Cruz Mountains Member No.: 106 Region Association: Northern California |
From the other thread on tire pressure, mine has Dunlop D60 (whatever that is) on 7x16's. 205/55/16.
carreraguy |
Sep 5 2006, 10:37 PM
It's not your dad's 914! Group: Members Posts: 1,197 Joined: 17-October 03 From: San Jose, CA Member No.: 1,256 Region Association: Northern California |
I'm running 6x16 front on 205/55 and 7x16 rear (944 Turbo Fuchs) on 225/50 (all Michelin SO-3's). No problems in the front at all but had to stretch the fenders a little in the rear for clearance. I'm pretty sure I could have even fit the 7's in front with no problem. You can see the left rear "stretch" in this pic.
Attached image(s) |
brownaar |
Sep 6 2006, 05:50 AM
Oh yeah, pics.
Attached image(s) |
brownaar |
Sep 6 2006, 05:53 AM
front and rear
Attached image(s) |
thesey914 |
Sep 6 2006, 06:30 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
My 914 has 7x16 with 205/50/16 all round. Car is slightly more built now.
Rear Camber is not set so rear wheel looks iffy.. Attached image(s) |
Rockaria |
Sep 6 2006, 07:49 AM
ZippidyDoDah... Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None |
7X205/55 16 With slight rear fender roll on rear. 6s up front.
(IMG:http://lib.nmsu.edu/~clandt/914/images/914it3.jpg) (IMG:http://lib.nmsu.edu/~clandt/914/images/914finalIT.jpg) |
Lo-Fi Version | Time is now: 5th June 2024 - 02:12 AM |
