Front Hood Alignment, ...so many corners |
7TPorsh |
Sep 14 2006, 03:39 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
Moviela |
Sep 14 2006, 08:05 PM
Newbie Group: Members Posts: 2 Joined: 7-September 06 From: CALIFORNIA Member No.: 6,792 |
Got the front lined up but having a problem with the back drivers side-seems to be a little high. How do I approach lowering that corner of the hood? Everything else seems to be lined up. The hinge consists of two parts, the moving part in German speak is lid hinge section, and the fixed part bolted to the wheel arch is the wheel arch hinge section. The hood (lid in German speak) has a bearing bolt that wants to be lubricated with chassis grease. Remove the lid, and release the tension of the extension spring if you want to remove it for inspection or cleaning and greasing. There are two hex bolts that attach the wheel arch hinge section to the body. There are oblong holes in the wheel arch hinge section to align the lid for height. Make sure that the bolts are lightly lubricated. For this I use lanolin, from sheep, to keep the corrosion off the hardware. Ever see a rusty sheep? (IMG:style_emoticons/default/thumb3d.gif) I get it from McMaster-Carr in Santa Fe Springs, CA. A few bucks for a tube, and they deliver overnight in SoCal. |
McMark |
Sep 14 2006, 09:53 PM
(IMG:style_emoticons/default/agree.gif) Nothing more to say. (IMG:style_emoticons/default/wink.gif)
So.Cal.914 |
Sep 14 2006, 10:43 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
I use lanolin on sheep too (IMG:style_emoticons/default/sheeplove.gif) ...... oh "from" sheep. Never mind.
Root_Werks |
Sep 15 2006, 07:36 AM
Village Idiot Group: Members Posts: 8,332 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
7TPorsh |
Sep 15 2006, 11:49 AM
Thanks!
Can I do this with the lid still on? |
Lo-Fi Version | Time is now: 4th June 2024 - 02:32 PM |
