RUBBER Boots for D-jet, found source |
Tom |
Sep 16 2006, 02:08 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Found two sources for the rubber boots for the fuel inj harness.
WWW.VOLVO-1800.com Fuel inj parts. Pt # 943693 two pin , Pt #945783 three pin, and Pt# 943695 four pin . Kit of 7 two pin , 2 three pin , and 1 four pin about $55.00 with shipping included. The local Volvo dealer can order the two pin ones for $4.00 ea. Are these prices reasonable? Tom |
bd1308 |
Sep 16 2006, 02:14 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
VERY reasonable.
Thanks! b |
type47 |
Sep 16 2006, 06:31 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
do you just stretch them over the plugs on the ends of the wiring harness? what else could you do?
bd1308 |
Sep 16 2006, 07:20 PM
buy a bowlsby harness....
JeffBowlsby |
Sep 16 2006, 07:51 PM
914 Wiring Harnesses Group: Members Posts: 8,530 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Hey I am glad you found these, I didn't know about them. They are a somewhat different design than the OEM boots, but they look like they should work. They are good for owners who dont need a new harness. The boots are important to protect the wiring from heat damage and the connections from contamination, both of which cause bad connections and FI 'issues'. I see the 5-pole boot is not available, but that boot is usually ok most of the time anyway becasue its up away from most of the heat.
StratPlayer |
Sep 16 2006, 07:55 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
So how do you put them on,,, does the harness have to be taken apart to get these boots on?
bd1308 |
Sep 16 2006, 07:59 PM
you need a special tool, called a modified jelwers screwdriver to push in a little clip inside the plastic connector, DO one wire at a time so you dont get them all mixed up--theyre all white. (IMG:style_emoticons/default/pinch.gif)
SirAndy |
Sep 16 2006, 08:04 PM
Resident German Group: Admin Posts: 41,673 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
you need a special tool, called a modified jelwers screwdriver to push in a little clip inside the plastic connector, DO one wire at a time so you dont get them all mixed up--theyre all white. (IMG:style_emoticons/default/pinch.gif) (IMG:style_emoticons/default/agree.gif) tiny flat screwdriver works very well ... (IMG:style_emoticons/default/smile.gif) Andy |
914werke |
Sep 16 2006, 08:45 PM
"I got blisters on me fingers" Group: Members Posts: 10,123 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
So a related question if buy chance Youve broken the tiny retaing tab in this process (IMG:style_emoticons/default/headbang.gif) Where can can you buy the male and female thingamajigs to replace?
bd1308 |
Sep 16 2006, 08:50 PM
you need a special tool, called a modified jelwers screwdriver to push in a little clip inside the plastic connector, DO one wire at a time so you dont get them all mixed up--theyre all white. (IMG:style_emoticons/default/pinch.gif) (IMG:style_emoticons/default/agree.gif) tiny flat screwdriver works very well ... (IMG:style_emoticons/default/smile.gif) Andy Jewlers screwdriver = tiny flat screwdriver. |
bd1308 |
Sep 16 2006, 08:51 PM
Rich, how many do you need?
I have a few I could send you. I was building harnesses as a side job, until I found that I may be steppign on peopel's toes. |
Lo-Fi Version | Time is now: 4th June 2024 - 11:15 PM |
